MAX7219 replacement for common anode 7 segment displays?
Hello. Is there a replacement for MAX7219, without adding extra functionality or details, which can drive 7 segment common anode displays? It should provide multiplexing and decode mode, just as MAX7219 does and have SPI interface. Sure, there are MAX6954 and some others, but they add unnecessary complexity and absence of sample code.
Sorry CuriousOne it won't drive CC LED display
Did you mean to say that it will not drive Common Anode?
As a partial solution, usable in some cases, ICM7217 from Maxim is also not a bad chip.
If agree to BCD input, bunch of NTE8374 or HEF4543B can be used, too.
