propellor c and compass sensor
It me again. This time I am having trouble setting up the code for a Parallax Compass Module 3-Axis HMC5883L in c. The trouble is not with the premade library functions for it but rather I cannot seem to create the i2c connection the sensor needs. I have tried multiple time using the code in both the simple tools and I2c libraries to no success. How do I open I2c bus? Please code example's if possible.
So, you've tried this code with the compass connected to P2/P3 and it doesn't work ?
/* Test Compass HMC5883L.c Test compass with SCL connected to P3 and SDA connected to P2. Display measurement results in SimpleIDE Terminal. learn.parallax.com/propeller-c-simple-devices/sense-direction-compass-hmc5883l */ #include "simpletools.h" // Include simpletools header #include "compass3d.h" // Include compass3d header int main() // Main function { int x, y, z; // Declare x, y, & z axis variables i2c *bus = i2c_newbus(3, 2, 0); // New I2C bus SCL=P3, SDA=P2 compass_init(bus); // Initialize compass on bus. while(1) // Repeat indefinitely { compass_read(bus, &x, &y, &z); // Compass vals -> variables print("%cx=%d, y=%d, z=%d%c\n", // Display compass variables HOME, x, y, z, CLREOL); float fy = (float) y; // Ints to floats float fx = (float) x; float heading = atan2(fy, fx) * 180.0/PI; // Calculate heading with floats if(heading < 0.0) // Convert -180...+180 to 0...360 heading = (360.0 + heading); print("heading = %.2f%c\n", // Display heading heading, CLREOL); pause(500); // Wait 1/2 second } }From the Learn/Simple Library repository.
