What do you use to do mechanical prototyping for your robotics?
In the past, I have used components from sets of Capsela, Legos, Tinkertoys, Erector and Meccano to prototype for small robotic projects.
The different variety of mechanical components allow for a large build set to draw from.
I also have a large collection of raw metal, plastics and wood that I can draw from to make custom components..which of course take longer to construct than just reaching for an ready made component.
So..what works for you for mechanical prototyping?
Lego and Vex are popular with the school crowd, where build speed and uniformity is important. And 3D printing is taught in schools now, that's a game changer.
I bet if you could find Lego and Vex parts made from nomex, high temperature tungsten and high impact carbon fiber, you'd be using more of those!
Depends what I'm doing at the time. Pre-made robots (S2), kits, baltic birch plywood, foam board, plastruct and metal tubing from the hobby shop, long screws and rods....I haven't figured out how to incorporate stained glass into a robot yet but given enough time.......
My recent Vex tread robot has one tread module made from expanded PVC but before I built it, I first made one from foam board. The foam board module will be replaced with an expanded PVC module.
Scratch building works well but takes time.
I find a combination of custom and premade parts work best for my prototyping.
And sometimes the prototype components end up in the finished robot..okay..who am I kidding..a REAL hobbyist robot is never finished. ;<)
Oops..forgot about Super Glue...how could I forget that!
=Usually= everything is bolted together, but I keep an assortment of adhesives on hand for things that are going to be permanently connected. I also keep Velcro strips and patches on hand.
"Stuff"... beyond that mentioned above:
Sheets of various kinds of plastic from Tap Plastics scrap bin
Aluminum stock... flat strips, angles, channels, sheets, spacers
Brass stock... flat strips, angles, telescoping tubing, threaded rod
Steel stock... plain rod (for axles)
Plastic stock... flat strips, angles, channels, plain rod, spacers, leftovers from Tamiya kits
Wood stock... various sized dowels
Hardware... various Parallax aluminum L/Universal brackets, 2-56 thru 1/4-20 screws, nuts and washers (mostly 3mm), various self tapping/wood screws
At work, we typically use T-Slotted aluminum since we have the budget for it and we have a small shop with all the required cutting and deburring tools.
As a mechanical engineer with 10+ years of design experience I decided to create a simple building kit that had a consistent professional look like T-Slotted aluminum but didn't require extra tools and wouldn't break the bank. I'd love to get some feedback from the prototypers here on if they think it would make prototyping easier. www.gridlinksinc.com
http://www.vslot-europe.com/index.php
I also use drinking staws. If one straw is not rigid enough, I slit a second straw, andslip this over the first. More layers are added until sufficent strength is attained. seven layers is just under seven times stronger than 1 layer (who'da thunk?). I 3D print a socket end, and touch it with a hot soldering iron to spot weld it to the end.
Not plywood, but may approach erco-cheap.
Interesting product, not interesting web site. I stayed about seven seconds. The concept seems a good one, but what's more important are pictures (and/or videos) showing REAL designs, not just 3D renders of things that maybe could work.
Agreed. I see what they are going for but that site needs some clear examples of real-world chassis and mechanisms created from it.
Also in those systems the hardware weight of the screws can become excessive.
At bit expensive, but the are very sophisticated and rugged.
http://blog.trossenrobotics.com/tag/dynamixel/
Dynamixels are really nice. My one complaint is they use a pot for position feedback like other servos. These pots will wear out with a lot of use. If you use your Dynamixel in something that you want to move a lot of the time, you'll likely wear out the pot before too long.
I keep trying to find a better way to sense position than using a pot. My experiment adding a magnetic encoder to a servo didn't work very well buy adding an optical encoder seems promising. The problem with the optical encoder is the lack of precision. I'm only getting 378 transitions per rotation which is a long way from the 10-bit precision of the Dynamixels.
Good ideas....need to add it to my component mix.
Thanks for posting it
