Decay times for the 10K potentiometer - (Parallax "Build your own mini timer" program
I have built the Parallax mini timer circuit and am having problems when I run the TestNumbers.bs2 program. Nothing shows up in the debug screen except zeros, unlike the video. Also, numbers do not show up on the 7-segment led as I turn the pot except for zero. Need help please. Thanks
2) Either provide copies of your circuit schematic and code or, at least, provide links to the Parallax examples if you haven't changed things at all.
http://forums.parallax.com/showthread.php/134682-Forum-Guidelines
Please continue this discussion in the original thread.
Thanks.
The big red wire in the center isn't connected to anything and the push button looks suspicious.
Check all the jumper wires for continuity or just replace them, they often develop internal breaks.
Here is a better photo. I was trying to detail the RC circuit in the last photo. Thanks for you valuable comments.
You can mouse click on your name when you are logged in and see a complete history of your post to locate the original. This thread was supposed to have been locked to force you and all others to go there.
But that didn't seem to happen. I replied with help for you in the original... try to locate it.
Hi j - the original post was in the Learn forum:
http://forums.parallax.com/showthread.php/113179-Build-Your-Own-Mini-Timer
However, both threads have progressed beyond my ability to merge them into one cohesive thread.
Yup, I know you're new. Part of the moderator duties are to gently direct new members into the "way of the Forum Guidelines".
http://forums.parallax.com/showthread.php/113179-Build-Your-Own-Mini-Timer?highlight=mini+timer
