Drive Coast to Coast on 10 Gallons of Gas?
Bodacious claims for this 3D printed car which is "two years away", but an interesting read nonetheless.
http://autos.yahoo.com/news/urbee-2--the-3d-printed-car-that-will-drive-across-the-country-000601366.html
Technically it seems ludicrous, we have what amounts to a toy car with a 7 HP engine supposedly getting 300 MPG whilst hauling about 300 lbs of meat(people) and who knows how much car averaging 75 MPH over a 3000+ mile course. I'd love to see that thing handle a steep grade or some black ice. Factor in with no power steering, no a/c, no heat, seats made of hard plastic that only a sadist could love, it's going to be one miserable drive.
This is hype.
I drove coast to coast RT last year, solo. Three days in each direction, ~900 miles a day, ~$100 a day for gas. Rented a car from LAX, unlimited mileage, $140 for the entire trip. They were pretty surprised to see nearly 5400 miles on the car when I turned it in.
I learned what DEF is on that trip at the truck stops. Who knows? No Googling!
And that was the Citro
What I have been able to read on the Future Fuels Rally, no one even mentioned 300 MPG engines. If they did achieve it, the contestants kept their traps shut and took that information to the grave.
For the Future Fuels 300MPG engines, they basically followed TD to the extreme. High exhaust temps, turbo charged blow-the-heads-off pressures, long stroke & low RPMs, all machining to mirror finish, plasma coated bearings through out, constant engine speed into an 8 speed transmission, rock hard tires, you get the idea... Plus we drafted a lot and even turned the engine off when going down hill or following a semi. And yes we helped each other out, but the technology in the engines was off limits. You either just knew how to do it, or you didn't.
