Does there exist a PS/2-Keyboard SENDER? — Parallax Forums
StefanL38StefanL38 Posts: 2,292
edited 2013-11-09 12:29 in Propeller 1
Hi,
a friend of mine will start an education to become a train-driver. There are various traim-simulation-softwares around. They all are controlled by the PC-keyboard.
Now I have the idea of building a train-cockpit with buttons, levers and steering wheel etc. To control a PC-software the propeller-chip must act as a keyboard.
Which means the propeller-chip is SENDING PS/2-signals (instead of reading them) The propeller-chip pretends to be a keybaord sending PS/2-signals.
Does there exist a PS/2-SENDER-object?
Could the USB-stack-object act as a USB-Keyboard?
best regards
Stefan
    edited 2013-11-02 13:36
    I do recall a thread that discussed using the propeller as a keyboard emulator but I do not know if anything came of it. Most if not all of the information needed to create such an object is be available in the keyboard/mouse objects so it should not be too difficult to create one if that is necessary.
    edited 2013-11-02 23:27
    I've also seen the discussed a couple of times. I don't recall anyone making it work.
    I think kwinn's "should not be too difficult" will depend a lot on one's programming experience. I personally think it would be pretty difficult though I like to think I could figure it out. In my limited experience it's a lot easy to write a driver which controls the clock line rather than trying to write a driver which listens to the clock line and sends the bits out on request.
    I hope you let us know if you get this to work.
    edited 2013-11-03 01:17
    If you look in the drivers for a PS2 keyboard or a mouse all the code is there as both require communications in both directions.
    You would have to adapt from a Master role to a slave role, and the really important little known fact is that communications are 12 bit serial in one direction and 13 bit serial in the other (I guess IBM added that to the specification just to sell more IBM keyboards).
    Nothing is quite as educational as a reverse-engineerring project like this. Now that you have the clues, good luck.
    Since you don't require handling keycodes with the additional complexity of multiple byte keycodes being converted to ASCII, I would use the Mouse driver as a first study and hack model.
    edited 2013-11-03 02:12
    Hi,
    thanks for your comments and suggestions,
    It sounds difficult and seems to be a lot of work to create PS/2-signals.
    @Loopy you are right great project to learn about programming data-transfer-protocols and programming in general.
    But that's not my main intention.
    So I chosed a different approach to solve the problem:
    The propellerchip is connected to the PC through a standard serial connection.
    Some years ago I coded quite a lot with delphi. So I started developing an application on the PC that receives the serial data from the propeller and sends keystrokes
    from my Delphi-App to the other software running on the PC using keyboard-events. On the PC-side there are several ways to to this: SendInput, Keybd_event, PostKeyEx32 etc.
    It's a little bit like in StarTrek NG: There are many ways to improvisate
    (just tech-nonsens) Geordi la Forge "if we connect the flux-compensator through a tachyion wire and a magnetic switch with the energyfield-amplifier we can get back control
    over the antimaterial-chamber... ;-) ;-)
    By the way: this is a typical example how telling what I want to do in the end opens new ways to solve a problem. In the end I want that it is possible that pushing real buttons
    and pulling real levers in some kind of locomotive-cabine (cockpit) makes a PC-simulation react on this pushing and pulling.
    In the PC-Software this is done through mouse-clicks or keyboard input.
    If I would have asked only for "how to create PS/2-signals?" to emulate a PS/2-Keyboard. Nobody could have ever the idea of how the final purpose can be done in others ways.
    So in my opinion it is always good to give the forum an overview about a project and a description of what is the final purpose.
    best regards
    Stefan
  • rosco_pcrosco_pc Posts: 472
    edited 2013-11-03 04:57
    edited 2013-11-03 07:12
    People are hesitant to give out this code because of potential nefarious use. That said, this is one of those infrequent times you are better served by Arduino. The Arduino mini has built in USB hid functionality and you can very easily emulate a keyboard or game controller. Examples are on the Arduino reference page of their website.
    edited 2013-11-03 07:58
    I can understand the comment about nefarious use, as there are devices that hacker's use to generate keyboard codes.
    But the interface is nothing more than SPI with 12 and 13 bit words instead of tidy 8 bit words. The biggest snag with the PS2 port is that the keyboard and the mouse can require 500ma of requlated 5VDC provided by the Master, but since the Propeller would be in a Slave role, the power requirement is moot. One may have to shift the outputs to +5 logic from +3.3 volt logic.
    I supect the USB keyboard mimic would be a bigger headache. First off, you would likely need the USB slave to identify itself as a keyboard or a mouse as opposed to a generic serial port. That means recoding the USB chips EEPROM to identify correctly. Since the Arduiino has a 'USB hide" function, I guess that may make a USB hack much easier.
    But the PS2 Slave emulation is certainly not rocket science. One can and should learn to bit-bang generic synchronous and asynchonous serial as fundamental building blocks for a lot of projects.
    Taking an 8 bit SPI driver and extending it to 12 or 13 bits is not hard. Combining the input and output signal to one wire is not hard either. But hacking and cracking USB ports and underlying computer BIOS calls are more involved. Name your poison.
    edited 2013-11-03 15:15
    Ahh Loopy, I like it, that's just what I would have said! :)
    @Stefan: As Loopy mentioned it's not rocket science, in essence putting aside the handshake and bidirectional part of it then it's only simple clocked serial, something that you could test in Spin in just a few minutes. If you keep it simple and test functionality first without all the possible combinations and functions you will see it is simple, then you can decide which functions and combination you need to implement. After all, keyboard controller chips were traditionally only primitive 8042 8-bit chips and you have the muscle of eight 32-bit 20MIP cores at your disposal.
    It's only complicated if you don't understand it and you will never understand until you roll up your sleeves and start learning.
    edited 2013-11-03 17:17
    I get what you are saying, Loopy. I've checked out the ps2 interface a number of times to see how to do one in the past. It is doable and a good learning experience. PS2 has some downsides - lots of systems don't have ps2 on them anymore and you can hot-plug ps2, it has to be there when you turn on the system. USB is really flexible and the Arduino mini makes it hugely stinking easy. Here is an example where a button is pressed and an 'a' keyboard press is sent to the host computer:
    // Arduino code from Arduino.cc/reference
    void setup() {
    // make pin 2 an input and turn on the
    // pullup resistor so it goes high unless
    // connected to ground:
    pinMode(2, INPUT_PULLUP);
    Keyboard.begin();
    void loop() {
    //if the button is pressed
    if(digitalRead(2)==LOW){
    //Send an ASCII 'A',
    Keyboard.write(65);
    It doesn't get any easier than this! The Propeller 2 may end up having some modifications to allow for built in or near built in serial capabilities on USB. Perhaps P2 will also have an HID USB object - that would be cool. Right now, doing USB keyboard on P1 isn't worth the overhead in my opinion, leaving the less optimal PS2 route left. That's why I'm recommending a different chip that has built in USB hardware.
  • TubularTubular Posts: 4,768
    edited 2013-11-03 23:33
    BradC's "California Dreaming" propeller demo acts as a USB keyboard, and enters the lyrics as if they were typed from a keyboard.
    edited 2013-11-04 00:12
    Very interesting. I would like a PS2 emulator in my Propeller arsenal as well for several reasons. My only method in the past has been to use relays to short pins from a PS2 Keyboard PCB together to send out PS2 characters to a PC.
    for those interested, here is the thread Tubular mentioned: http://forums.parallax.com/showthread.php/97027-California-Dreamin
    edited 2013-11-04 14:34
    Anybody know how much resource wise the bradC USB keyboard lyric demo consumes?
    edited 2013-11-04 18:48
    IIRC, too much, but it does demonstrate it can be done although only slow. Now to make it less resource hungry and faster.....(I think that's P2 cue).
    @ALL: I don't mind writing a sample PS/2 sender as I have written PS/2 and ADB keyboard emulators, except I would do it in Forth. If anyone really wants to then they can convert it to Spin which should be easy enough. (provided it's fast enough).
  • MJBMJB Posts: 1,235
    edited 2013-11-08 19:02
    a non-Prop USB Keyboard AVR ATmega8 + BASCOM with soft low speed USB1.1
    http://www.mcselec.com/index.php?option=com_content&task=view&id=322&Itemid=57
    edited 2013-11-09 00:00
    In Forth? Of course ! ! !. The clock rate doesn't have to be ightning fast as it never was. SPI doesn't require a PASM solution, but it does help that Forth is faster than Spin.
    Since the SPI comms require every device to keep up with a clock generated by any other, you have to be able to respond at the maximum clock speed of 16 KHz. This is pretty tight in Spin, as that only gives you about 25 Spin tokens per clock to WAITPEQ the clock edge, capture and shift in the bit, and test to see if the frame is over before looping back to WAITPEQ. It might be do-able but will be close. To do an I2C slave at 70 KHz I had to resort to PASM, and the Keyboard object in the obex uses PASM. Forth or Hub RAM byte code GCC would probably be able to do it more reliably.
