Why do flashing things appear on and not off? — Parallax Forums
PoundSign2PoundSign2 Posts: 129
edited 2013-11-03 18:16 in General Discussion
So I was watching a video on joule thief circuits since it's something I've never actually built, and I think my son would enjoy building one with me for the first time plus a great learning opportunity. While the basis behind this circuit is simple, it gains high voltage allowing sufficient current to flow in and out of the LED. This happens very quickly, so quickly in fact that it just appears as "On" all the time. We can say that the LED is also on an equal amount of time that it is off. And if On is the opposite of Off and vice verse, and things of equal and opposite value cancel out... why then does the LED appear on and not off?
My main hunch is that it has to do with something about the time it takes for the light to hit your eyes and something related to our max FPS or something. In any case I find this a fascinating question. What's your take?
  • Mark_TMark_T Posts: 1,981
    edited 2013-11-02 04:42
    You confuse two kinds of opposite - to humans on and off are "opposite" in a very sloppy sense - it
    is either on or off, therefore they are opposites.
    But mathematically the term for opposite is "inverse" and the additive inverse of 1 is -1, not 0.
    Since an LED cannot absorb light the same way as is emits, the average of being on and off
    is being half-on. When its on its emitting photons of light, when off its not emitting photons
    of light, therefore if its on half the time it emits, time-averaged, photons at half the rate.
    [ consider this: is the opposite of running standing still? Or is it running backwards? If you
    spend 1 minute running, then 1 standing still, then 1 running, etc etc you are still going forward ]
  • doggiedocdoggiedoc Posts: 2,252
    edited 2013-11-02 04:47
    It appears on because of persistence of vision. The same thing that makes animation appear fluid.
    http://en.wikipedia.org/wiki/Persistence_of_vision
    edited 2013-11-02 07:52
    It's a bit like is a glass of beer half empty or half full? I'm with doggiedoc about the persistance of vision , Think how many photons have hit the eye in even a short on period. also there is more brain response to the flash of light as opposed to an off led which would merge into the background.
  • whickerwhicker Posts: 749
    edited 2013-11-02 10:48
    I like Mark_T's explanation the best.
    The LED would have to draw all the light it emitted back into itself.
    edited 2013-11-02 11:00
    Your eyes respond to the accumulation of photons and you see light.
  • jonesjones Posts: 281
    edited 2013-11-02 11:51
    That's a really interesting question. I would suspect it has to do with the difference between the way the eye-brain system perceives light vs. how it perceives an absence of light. The response to the onset of light stimulus must be faster than the response to the end of that stimulus. Photoreception/transduction is a *really* complicated system ( e.g. http://en.wikipedia.org/wiki/Photoreceptor_cell ).
    I found a discussion of the details: http://webvision.med.utah.edu/book/part-viii-gabac-receptors/temporal-resolution/
    edited 2013-11-02 12:21
    It's all about contrast. A half-lit, 50% PWM LED will be perceived as "plenty bright" in a dark room. But in a bright room, you'd be hard pressed to tell if it was on. Traffic signals are usually nice & bright and easily visible, but when the sun is setting behind it, you often can't tell.
    edited 2013-11-02 13:40
    Mark_T wrote: »
    This is starting to sound like the jet on the treadmill problem.
    As for the LED blinking, I'm going for persistence of vision and some psychological bias our brains have.
    edited 2013-11-02 14:06
    Actualy erco's post made me rethink and it could be to do with contrast, consider a chase of leds if you flash one led in a sequence the one on it's own lit as "dot" becomes the focus but consider the chase again in "bar" ie only one led is off at any one time then that off led becomes the focus.
    edited 2013-11-02 14:44
    Well, permanently on or not there is still energy coming out of that LED into your eye in the form of photons. What do you expect that energy to do? Nothing? Something?
  • PoundSign2PoundSign2 Posts: 129
    edited 2013-11-02 20:55
    Heater. wrote: »
    The meaning of life is more accurate.
    edited 2013-11-02 21:06
    skylight wrote: »
    Actually, skylight's post #4 mentioning beer made me rethink and down a frosty Corona. I no longer care about these errant photons.
    edited 2013-11-02 23:58
    PoundSing2,
    Err...what? I did not understand that.
    edited 2013-11-03 03:55
    Heater. wrote: »
    PoundSing2,
    I suspect he forgot the add [noparse]</sarcasm>[/noparse] at the end.
    edited 2013-11-03 05:18
    Is this a contest?
    edited 2013-11-03 05:59
    If I only spill half a glass of water why does the floor still get wet?
    C.W.
    edited 2013-11-03 13:29
    You must have consumed the half full portion as opposed to the half empty :smile: Does that make you half cut?
    edited 2013-11-03 14:24
    Heater. wrote: »
    PoundSing2,
    You asked what you wanted the energy to do for us. I wanted it to solve a riddle. Yes, it was sarcasm. :P
    In any case I put some more thought into it and I think there is another variable we did not consider. The ambient light. Light that is also coming from other angles being absorbed and reflected by the red/green/blue/clear cap on the end. Light from other angles could hit the cap and come back to you, filling in that 'delay' of OFF/ON time that light is emitted from the LED. So if the the LED is on 50% of the time, the other time it is off the ambient light could fill in that 'gap' that it is off. IDK, just a thought. Credible or totally off the mark?
    edited 2013-11-03 15:33
    PoundSign2 wrote: »
    Considering the phenomenon can happen in a totally dark room, I doubt it.
    I have another version of this question: considering the brains of 99% of the people are working only 1% of the time, why doesn't everyone think they're entitled to my opinion?
    edited 2013-11-03 16:59
    I just ran a full marathon today, and a half full beer on a treadmill still looks good to me.
    edited 2013-11-03 17:15
    I probably would have picked the 1/2 marathon and the full beer.
    mindrobots wrote: »
    My ignorance is complete, m'lord abbot.
    That's an obscure quote from "A Canticle for Leibowitz". But in a related story, Jesus stole all the marathon headlines today (maybe wine, but no beer):
    http://news.yahoo.com/nyc-marathon-jesus-200033428.html
