74HC165 with logic high
Hello,
I am using 16 of the Piezo Film Vibra Tab as trigger switches for an exhibit at our museum (a 16 step musical stairs!). As you can imagine, I can't dedicate all of my BS2 pins to that.
I have used the 74HC165 with switches before and how to chain them to read more than 8 inputs. But I have no idea how to use them with Piezo sensors which output +5V (using a 5.1V Zener diode for protection).
Is there a simple trick to use the 165 for this purpose? If not, is there an alternative?
Many thanks in advance.
Al
Al
74VHC165
74AHC165
can handle 7v on inputs though even if its Vdd is 3.3v
many thanks Chris.
I finally decided to introduce a very simple circuit between the Piezo and the 74HC165 which consists of a simple PNP transistor and Reed relay. This will eliminate all the logic issues and the need for 2 BS IIs.
Thanks all for the responses.
Al
many thanks to all for your help
Al
