Glueing Heat Shrink Tube
I need to glue some heat shrink tube that are covering servo wires to a metal tape measure and I need to make sure that it never comes off. What can I use that will accomplish this without any damage to the heat shrink tubing? I have some 3M spray adhesive but I am not sure it would be a good permanent solution.
Is there any way you can slip a sleeve of heat shrink tubing over the entire assembly and shrink it on? (If so, be careful the metal edge can't cut the tubing.)
This was my first thought too. You could put some electrical tape (kapton would be my first choice) or similar on the edges first to prevent it from cutting the heat shrink.
For a gluing solution I would use Goop - super tough and flexible.
I use Goop AKA Shoe Goo for everything. There's only a few plastics that I've found it doesn't stick to.
