Website problem
Buck Rogers
Hello!
I'm in the process of researching one or more new projects, of which a lot of them will contain Parallax components. I found the Small Robot Chassis that the BOE Bot and the the idea for the Arduino stand on, and also the Prop Activity Bot use. That's at http://www.parallax.com/product/700-00022 however when I tried to bring up the PAB which is supposed to be at http://www.parallax.com/home-page-banner/activitybot-robot Instead of being greeted with a description of the PAB, I get "Access Denied".
Huh? I thought the only thing private outside of customer records, was the education fora on this site?
Shouldn't I a regular customer be able to see the PAB before trying to decide if I want to invest in one, rather then reinvent the wheel, amongst other moving devices?
Now I am confused...........
Is this fellow with the Wall-I grin http://www.parallax.com/product/32500 the same fellow as the link above?
The link you tried first is not a valid link to the ActivityBot product page, the link you should use is http://www.parallax.com/product/32500.
If you're interested, http://learn.parallax.com also has a number of tutorials and projects for the ActivityBot that showcase its abilities.
Courtney
Hello!
Rick, you win the prize. Better not ask what.....
Courtney, that is what I mean, what about changing the link shown there as RDL2004 suggests?
Bad links can also be reported to webmaster@parallax.com.
Courtney
Hello!
Thank you!
