Using Propeller Project Board with QuickStart modules
David Betz
Is there some trick to using QuickStart modules with a Propeller Project Board? I just soldered a female 20x2 header to my Rev A Project Board and plugged in a Human Interface Board with a Propeller Memory Card plugged into it and it doesn't seem to work. The same HIB+PMC works when plugged into a QuickStart board. Is there some jumper I have to use to enable the QuickStart header on the Project Board? Also, I assume that the QuickStart module should be plugged in so that it overlaps the Project Board like it does the QuickStart board, right? It isn't supposed to hang off the side is it?
Anyway, thanks for the information. I hope I didn't fry the Project Board, the HIB or the PMC by plugging it in backwards!
Did you power the HIB through the onboard jack? If you did I/O P0 could possibly be damaged. If you were powering the boards through USB on the Project and QS, I don't think there should be any damage done. At least not to each Prop board or the HIB. There is a chance the PMB could have been damaged.
Plugging the HIB backward puts 5V on P0. This is the IO0/DI pin on the PMB. It also reverses the power to the memory chips (could be bad).
