Plug-in XBee Adapter for the S2
The S2's DB-9 serial connector provides battery power (Vin) to pin 8. This allows for the possibility of plug-in modules that receive their power from the S2. A natural use for this capability is an adapter for the XBee family of wireless interface modules, so I decided to make one. This was kind of a stealth project that I designed one day last week on a whim. The boards arrived today, and I'm happy to say that they work! Here's a photo:
Because the XBees run on 3.3V, and the XBee Pro requires up to 215 mA during transmit, it was impractical to step the battery voltage down with a linear regulator. So, in order to save wasted power and heat, I've included a switching regulator circuit on board the adapter. Also, since the S2 provides and requires RS232 (inverted) serial, it had to include transistor inverters. Other than that, it's a small, simple device that fits entirely within the S2's turning radius and doesn't cover up the LEDs or get in the way of the power switch or input button.
I have no idea yet about manufacturing or even whether there'd be any demand for such a device. Is this something that people might want?
S2 x 3
Roving Network WiFi??
The people will also want instruction and demonstration...
oh, and the people would really like schematics too.
Go! Phil Go!
-Tommy
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/bluewolf/List/0/SortField/4/ProductID/752/Default.aspx
The Bluewolf module is paired with their XBee host board, but it won't work with either Scribbler model. So if you could get it to work with a Boe-bot as well it would be great. I plan to pair the Bluewolf module with a Wixel and take a crack at wireless programming of the Boe-bot.
Hello Phil,
Nice project! I think there is definitely interest in these. In regards to the power can't you just add a 3-pin SIP header and use a jumper to select which pin provides power? Either that or pads that could be solder bridged to select the voltage. You could put a tiny trace between the two as the default for the S2 which could be easily cut when you want the other power source.
Robert
Todd
Joshua
I am now shoehorning the XBee inside the S2 (Yes inside ...the idea of plugging onto the RS232 thingy eluded me ..Duhh ).......
I am successfully using it as a Cable-Free link using the Tiny Logo OBJ shown in the forum post "Here"
I have reduced the XBee power setting to its lowest setting as i don't envisage out of site control (just to prolong operation).... i think the S2s Hacker port 5 volt is any-ways rated for 1.2 A max (correct me if i am wrong)
Thanks for the continued interest -- and your patience! I was holding off because I wanted to pair it with a joystick-type remote controller. But I've come to the conclusion that there is a better way to go about that part. So the plan now is to proceed with the adapter by itself. I've got another loooong-awaited module going into production now (1500 boards made and a quote for the assembly). When that's out the door, I can revisit the XBee adapter.
BTW, because of all the SMD parts, it will probably come premade -- or possibly as a semi-kit, with only the through-hole parts to solder. The latter is a little harder, though, since testing is not as easily accomplished.
So that leaves wireless data exchange with the S2, which the XBee module can still handle. But I'm not sure how much interest remains for such an app.
Email me your postal address, and I'll send you one of the plug-ins to try out with your WiFly module.
