TableBot Challenge: Sensor selection for table edge detection?
I have been reviewing the setups needed for the Robogames Tablebot Challenge and from that I am looking for a way to add sensors to the front of my "candidate" to give it eyes to the table surface. I simply want a ON or OFF state sensor depending on if it detects the table when then sensor is mounted from 0.5-2" from the table surface. Basically, if it sees the table, I would like an "OFF" or Low output. When the table is not seen (when it is looking over the edge to the floor), it would present an "ON" or high output. If the outputs are opposite, I can correct them easily with a couple added parts.
From looking around at various options, these look like the best option: QTR-L-1A Reflectance Sensor (2-Pack)
But, I am also looking at Parallax's QTI sensor, 555-27401, and the plethora of options for Sharp's "hobbyist standard" IR sensor. However, both of those are more expensive and one of my goals is to keep cost down in case I want to sell kits of my design.
INPUT????
INPUT????
John Abshier
