$1.56 4 IN 1 Multi Test Meter
I have NO idea what this thing does, but it sounds so great that I just had to order one. Duane, Martin_H?
This is a 4 IN 1 Multi Test Meter AOK,For ESC Tester; Servo Tester; PPM singal (sic) Tester; Temperature Gauge.
http://www.ebay.com/itm/4-IN-1-Multi-Test-Meter-AOK-For-ESC-Servo-PPM-singal-and-Temperature-HS-/221228567814?pt=LH_DefaultDomain_0&hash=item3382400d06
Here is a link to a copy of the manual: http://abc-rc.pl/templates/images/files/995/4in1-multi-test-meter-user-manual.pdf
But, be sure to read the * marked red line, on page one.
It seems you are about to search for a good rebate for the AOK-BL8S item too, since both are meant to be used in conjunction.
Here is a good picture of it, both sides shown:
Googleing AOK-BL8S, I've found it at: http://www.nitroplanes.com/79p-8003-voltagemonitor.html
The following video shows some similar function in operation:
Yanomani
This "AOK" LCD battery tester/balancer popped up, too. Looks nice, will have to shop around: http://www.ebay.com/itm/AOK3in1-RC-2s-6s-Lipo-Li-Fe-Battery-Balance-LCD-Voltage-Meter-Tester-Discharger-/181225653106?pt=Radio_Control_Parts_Accessories&hash=item2a31e40372
$2.33 shipped if anyone needs one
This time you've put down the price tag to less than half, based on the one I'd found.
I am also looking for any rebate on my fat mass, from the current 103 kg to something like 80 kg! Could you give some help to me, one more time?
Apart from kidding, I was a bit unlucky, searching for the AOK-BL8S manual.
Thanks for sharing all the good stuff you usually show us!
Yanomani
