So, I guess one can dispense with the font[] array in the VAR section if defining one's own font in a DAT section (someone correct me if I'm wrong).
Marko's demo is cool, particularly the way it rotates the custom font (scroll-like). As another example, the code below is a rudimentary test that I made, which simply replaces Marko's "selftest" PUB method (and the VAR section may optionally be commented out):
PUB selftest : c
vga.init
vga.str(string(vga#ESC, "s")) ' page mode
vga.str(string($A,12,$B,2,"Custom Font Test"))
vga.str(string($A,16,$B,5,"0 1 2 3"))
vga.str(string($A,16,$B,6,"-------",$A,16,$B,7))
repeat c from 0 to 3 'output 1st four ROM font characters
vga.putc(c)
vga.putc(" ")
'non-changing chars (shows that chars>31 are constant)
vga.str(string($A,7,$B,10,"abcdefghijklmnopqrstuvwxyz"))
vga.str(string($A,7,$B,11,"ABCDEFGHIJKLMNOPQRSTUVWXYZ"))
repeat 'alternate between ROM and Custom fonts
vga.setn(1, constant(NEGX|$8000)) 'use the ROM font for chars 0..31
waitcnt(clkfreq*2+cnt)
vga.setn(1, NEGX|@user_font) 'use the custom font for chars 0..31
And below is some sample custom font data (for 4 characters) for a DAT section to go along with the above test code:
As suggested by kuroneko (Marko), this custom font-definition technique (the format/math) is from localroger (Roger Williams). Thanks to both!!
DAT
*** This technique is from Roger Williams' vga_40x18_rom_demo.spin v1.1 ***
The user defined chars must be reversed and interleaved like the ROM font,
but in order to save memory they are only 16 pixels high. This example
shows a way to draw the font forward and un-interleaved so that the
proptool will assemble it correctly. Draw the left/lsb=0 character with
2's and the right/lsb=1 character with 1's. The reverse and add
operations will take care of the interleave.
user_font 'beginning address of user's custom font data
'Custom Font Data for Chars 0 & 1
C00_01 long %%22222222_22222222 >< 32 + %%11100000_00000111 >< 32
long %%22200000_00000222 >< 32 + %%01110000_00001110 >< 32
long %%22200000_00000222 >< 32 + %%00111000_00011100 >< 32
long %%22200000_00000222 >< 32 + %%00011100_00111000 >< 32
long %%22200000_00000222 >< 32 + %%00001110_01110000 >< 32
long %%22200000_00000222 >< 32 + %%00000111_11100000 >< 32
'Custom Font Data for Chars 2 & 3
C02_03 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32
@localroger: Thanks for creating and sharing that great technique for keeping one's sanity in defining custom characters in a DAT section.
PUB selftest : c vga.init vga.str(string(vga#ESC, "s")) ' page mode vga.str(string($A,12,$B,2,"Custom Font Test")) vga.str(string($A,16,$B,5,"0 1 2 3")) vga.str(string($A,16,$B,6,"-------",$A,16,$B,7)) repeat c from 0 to 3 'output 1st four ROM font characters vga.putc(c) vga.putc(" ") 'non-changing chars (shows that chars>31 are constant) vga.str(string($A,7,$B,10,"abcdefghijklmnopqrstuvwxyz")) vga.str(string($A,7,$B,11,"ABCDEFGHIJKLMNOPQRSTUVWXYZ")) repeat 'alternate between ROM and Custom fonts vga.setn(1, constant(NEGX|$8000)) 'use the ROM font for chars 0..31 waitcnt(clkfreq*2+cnt) vga.setn(1, NEGX|@user_font) 'use the custom font for chars 0..31 waitcnt(clkfreq*2+cnt)As suggested by kuroneko (Marko), this custom font-definition technique (the format/math) is from localroger (Roger Williams). Thanks to both!!
DAT { *** This technique is from Roger Williams' vga_40x18_rom_demo.spin v1.1 *** The user defined chars must be reversed and interleaved like the ROM font, but in order to save memory they are only 16 pixels high. This example shows a way to draw the font forward and un-interleaved so that the proptool will assemble it correctly. Draw the left/lsb=0 character with 2's and the right/lsb=1 character with 1's. The reverse and add operations will take care of the interleave. } user_font 'beginning address of user's custom font data 'Custom Font Data for Chars 0 & 1 C00_01 long %%22222222_22222222 >< 32 + %%11100000_00000111 >< 32 long %%22222222_22222222 >< 32 + %%11100000_00000111 >< 32 long %%22222222_22222222 >< 32 + %%11100000_00000111 >< 32 long %%22200000_00000222 >< 32 + %%01110000_00001110 >< 32 long %%22200000_00000222 >< 32 + %%01110000_00001110 >< 32 long %%22200000_00000222 >< 32 + %%01110000_00001110 >< 32 long %%22200000_00000222 >< 32 + %%00111000_00011100 >< 32 long %%22200000_00000222 >< 32 + %%00111000_00011100 >< 32 long %%22200000_00000222 >< 32 + %%00111000_00011100 >< 32 long %%22200000_00000222 >< 32 + %%00011100_00111000 >< 32 long %%22200000_00000222 >< 32 + %%00011100_00111000 >< 32 long %%22200000_00000222 >< 32 + %%00011100_00111000 >< 32 long %%22200000_00000222 >< 32 + %%00001110_01110000 >< 32 long %%22200000_00000222 >< 32 + %%00001110_01110000 >< 32 long %%22200000_00000222 >< 32 + %%00001110_01110000 >< 32 long %%22200000_00000222 >< 32 + %%00000111_11100000 >< 32 long %%22200000_00000222 >< 32 + %%00000111_11100000 >< 32 long %%22200000_00000222 >< 32 + %%00001110_01110000 >< 32 long %%22200000_00000222 >< 32 + %%00001110_01110000 >< 32 long %%22200000_00000222 >< 32 + %%00001110_01110000 >< 32 long %%22200000_00000222 >< 32 + %%00011100_00111000 >< 32 long %%22200000_00000222 >< 32 + %%00011100_00111000 >< 32 long %%22200000_00000222 >< 32 + %%00011100_00111000 >< 32 long %%22200000_00000222 >< 32 + %%00111000_00011100 >< 32 long %%22200000_00000222 >< 32 + %%00111000_00011100 >< 32 long %%22200000_00000222 >< 32 + %%00111000_00011100 >< 32 long %%22200000_00000222 >< 32 + %%01110000_00001110 >< 32 long %%22200000_00000222 >< 32 + %%01110000_00001110 >< 32 long %%22200000_00000222 >< 32 + %%01110000_00001110 >< 32 long %%22222222_22222222 >< 32 + %%11100000_00000111 >< 32 long %%22222222_22222222 >< 32 + %%11100000_00000111 >< 32 long %%22222222_22222222 >< 32 + %%11100000_00000111 >< 32 'Custom Font Data for Chars 2 & 3 C02_03 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32 long %%22222200_00000000 >< 32 + %%00000000_00111111 >< 32
