You can't get this with surface mount technology — Parallax Forums
xanaduxanadu Posts: 3,347
edited 2013-10-20 21:39 in General Discussion
You can't use the space better than some 3mm Red LEDs. Anyone know what this is? I'll give you a hint, 480v input.
    edited 2013-10-17 22:29
    A rather large UPS?
  • JordanCClarkJordanCClark Posts: 198
    edited 2013-10-18 03:54
    Looks rather like a PLC, or PC-based rack system. I see three input cards, 2 output cards, though the labeling indicates a third one out of view of the shot.
    It almost looks like enough LEDs to be 32-bit I/O...
  • Mark_TMark_T Posts: 1,981
    edited 2013-10-18 08:53
    Is it a very expensive room heater? :)
  • MoskogMoskog Posts: 556
    edited 2013-10-18 10:09
    Humanoido project finally materialized?
  • bomberbomber Posts: 297
    edited 2013-10-18 14:52
    It looks like it could be a timing controller for a large fireworks show. The large bundles of wires would make sense for this, and the 480V could be used to ignite the fuses...
    edited 2013-10-18 14:53
    On second thought, it could be some form of substation control system, handling the switching of current throughout the station?
    edited 2013-10-18 14:55
    or maybe it could be a lighting control system, for a theater or stage? (Does anyone know how to turn a brain [particularly mine], off?)
    edited 2013-10-18 16:51
    bomber wrote: »
    Facebook and Farmville......unless (shiver) all those people were like that to start with!
    edited 2013-10-18 17:30
    I would...but my parents say that I'm 'too young'.
    edited 2013-10-19 05:43
    I know some people who play Farmville...
    And it's an even distribution of vegetables and ordinary people turned vegetable...
    Bomber; be very, very thankful to your parents because they have saved you from a digital lobotomy.
    And never let anyone switch off your brain.
    Anyway, the squibs they use to set off fireworks, or hobby rockets, works just as well at 12V.
    The mystery box has 480V inputs. I notice there's no mention of any 480V outputs... or whether it's AC or DC...
    Isn't 480V DC what's commonly used to run subways and similar transportation systems?
  • xanaduxanadu Posts: 3,347
    edited 2013-10-19 07:51
    There are some pretty close responses, I suppose this board could be in a number of things and you'd have to be experienced with this manufacturer to recognize the actual unit it belongs to. So, here are some hints.
    Hint #1: You would find this in a large room or warehouse. There could be one or a lot of them. It is loud, and has a very distinct smell.
    Pic #2:
    edited 2013-10-19 07:56
    Farmville!? Haha I will never play it but I love it because it exposed tons of anti-gaming hypocrites.
    I wish they had Pharmville where you phreak peoples pharms.
    edited 2013-10-19 08:02
    Here it the DC side of the power supply.
    [IMG][/img]242s9s6.jpg
    edited 2013-10-19 15:27
    Jeez that is a lot of fans! I wonder if it is the control system for a crane or other form of transportational system.
  • PoundSign2PoundSign2 Posts: 129
    edited 2013-10-19 18:24
    You're right. SMD tech wouldn't take up nearly that much space or produce as much heat. lol
    My guess is that it looks like something for Elevators. The Relay Systems in elevators sometimes look a good bit like that. I'm probably very off though. Looks fun to take apart though. :)
    edited 2013-10-19 18:48
    xanadu wrote: »
    You would find this in a large room or warehouse. It is loud, and has a very distinct smell.
    OMG, is it ME?
    edited 2013-10-19 19:13
    I say TELCO stuff ........
    edited 2013-10-19 19:31
    TELCO stuff will be 48V DC if it's in a central office. No reason it would be in a warehouse specifically or have a unique smell.
    erco beat to to my guess (I was going to guess me, not Eric!)
  • TumblerTumbler Posts: 323
    edited 2013-10-19 20:14
    Maybe a 'Power Network Center '?
  • SRLMSRLM Posts: 5,045
    edited 2013-10-19 20:36
    It's a battery charger?
    edited 2013-10-20 08:34
    Hint #2: I was installing serial to Ethernet adapters to replace the use of a floppy drive or manual keying.
  • Tim-MTim-M Posts: 522
    edited 2013-10-20 09:17
    Is it a commercial transmitter of some sort?
    edited 2013-10-20 09:24
    It's the controller for some sort of robot/automated retrieval system?
    edited 2013-10-20 10:28
    I'm thinking maybe some sort of inventory tracking, but the "has a distinct smell" part is really throwing me off.
    Is it the control system for a loading dock? (controlling the doors, ramps, lifts, etc. ) That would explain the high voltage, noise, and hey, I don't know, maybe it has a smell too.
    Maybe some sort of fluid control system?
    Not sure why either one of these requires an Ethernet control system but Industrial electronics is not my forte.
    edited 2013-10-20 11:04
    After blowing up the picture of the controller I could see it operates motors of different types.
    edited 2013-10-20 11:07
    Electronics/control system of a CNC machine maybe, the cabinet color looks like Fadal anyway...
    edited 2013-10-20 13:58
    Tim-M wrote: »
    We have a winner! You're quite correct it is an Okuma 5 axis mill. The distinct smell would be cutting fluid.
    I got to install around 40 Predator DNC systems on a variety of mills, lathes, and indexers, really neat stuff! It's serial over wireless. I get to do these installs because I can setup secure wireless networks. Glad that can cross me over into fun jobs like this!
    edited 2013-10-20 13:59
    Thanks for playing along that was fun :)
    Thanks for the challenge Xanado, it was fun to try and figure out!
