Looks rather like a PLC, or PC-based rack system. I see three input cards, 2 output cards, though the labeling indicates a third one out of view of the shot.
It almost looks like enough LEDs to be 32-bit I/O...
It looks like it could be a timing controller for a large fireworks show. The large bundles of wires would make sense for this, and the 480V could be used to ignite the fuses...
I know some people who play Farmville...
And it's an even distribution of vegetables and ordinary people turned vegetable...
Bomber; be very, very thankful to your parents because they have saved you from a digital lobotomy.
And never let anyone switch off your brain.
Anyway, the squibs they use to set off fireworks, or hobby rockets, works just as well at 12V.
The mystery box has 480V inputs. I notice there's no mention of any 480V outputs... or whether it's AC or DC...
Isn't 480V DC what's commonly used to run subways and similar transportation systems?
There are some pretty close responses, I suppose this board could be in a number of things and you'd have to be experienced with this manufacturer to recognize the actual unit it belongs to. So, here are some hints.
Hint #1: You would find this in a large room or warehouse. There could be one or a lot of them. It is loud, and has a very distinct smell.
You're right. SMD tech wouldn't take up nearly that much space or produce as much heat. lol
My guess is that it looks like something for Elevators. The Relay Systems in elevators sometimes look a good bit like that. I'm probably very off though. Looks fun to take apart though.
I'm thinking maybe some sort of inventory tracking, but the "has a distinct smell" part is really throwing me off.
Is it the control system for a loading dock? (controlling the doors, ramps, lifts, etc. ) That would explain the high voltage, noise, and hey, I don't know, maybe it has a smell too.
Maybe some sort of fluid control system?
Not sure why either one of these requires an Ethernet control system but Industrial electronics is not my forte.
Electronics/control system of a CNC machine maybe, the cabinet color looks like Fadal anyway...
We have a winner! You're quite correct it is an Okuma 5 axis mill. The distinct smell would be cutting fluid.
I got to install around 40 Predator DNC systems on a variety of mills, lathes, and indexers, really neat stuff! It's serial over wireless. I get to do these installs because I can setup secure wireless networks. Glad that can cross me over into fun jobs like this!
Pic #2:
I wish they had Pharmville where you phreak peoples pharms.
[IMG][/img]
OMG, is it ME?
TELCO stuff will be 48V DC if it's in a central office. No reason it would be in a warehouse specifically or have a unique smell.
erco beat to to my guess (I was going to guess me, not Eric!)
