CR Servo Question
I was looking on EBay the other day and seen several dual horned servos but for the life of me I can not remember what they are called and sure enough I can not find them again. I beed the continuous rotation servos that are used in Biped type walers, etc. with horn attachment on both sides. Any suggestions?
Many, if not most servos come with this type of horn. Though they might not be as long as the horns you have in mind. Some hobby shops sell just the horns. You need to make sure you get the right kind of horn to match the brand of your servo. Different brands have different numbers of spines on the servo output shafts.
Your title has "CR Servo". Most servos are not continuous rotation but can usually easily be modified to be so. This servo from HobbyKing is one of the easiest servos I've found to convert to CR. It also has a double horn.
I think the double horns are often used with RC airplanes' ailerons. A lot of the servos I've seen for sale include a picture of the horns which come with the servo.
How strong does your servo need to be?
I also see that Trossen has some cheaper analog ones.
The servos listed don't really have two horns but rather a pivot point on one side. I used Lego turntables to add a pivot point to the back of my servos in my Popsicle stick hexapod.
Digital servos can be usually swapped in for analog servos, but there are some differences to be aware of, higher power requirements among them. http://www.futaba-rc.com/servos/digitalservos.pdf
