preserving as much precision as possible — Parallax Forums
tosjduenfstosjduenfs Posts: 37
edited 2013-10-17 21:48 in Propeller 1
I've been working on code that converts a stellar objects RA/DEC coordinates to ALT/AZ coordinates. Basically I first calculate the number of days it has been since Jan 1, 2000 (J2000) and then through a series of calculations I can determine and track where an object should be in the sky given my geographical coordinates and my local time.
In my first attempt I calculated the time since J2000 in decimal days using the float32 object. Unfortunately due to the size of the numbers involved and the lack of precision of a 32 bit floating point number my program would only generate new ALT/AZ coordinates every ~50 seconds or so (when enough time had passed that the last digit of JD changed) rather than every second as the program is written.
So the plan now is to convert the code to use integer seconds rather than decimal days. I've successfully changed the time calculation to accurately give seconds as an integer rather than decimal days but now I am not sure on how to continue using integer math. The next step is to use the following formula to find Greenwich Mean Sidereal Time:
GMST = (280.46061837 + 360.9856473662862*D) mod 360 ' where D is days since J2000 and GMST is in degrees (as of writing this post D = 5036.795139 days)
This formula is accurate to 0.1 seconds over a century but all I really need is for it to be accurate to a few minutes of actual GMST and to have a precision of 1 second so that I can generate new ALT/AZ coordinates every second for tracking.
If I were still using floating point math I would have no problem converting the formula but I'm not exactly sure how to do it with integer math while preserving as much precision as possible.
Any tips would be appreciated. I can post my code later tonight when I get home if that would be more helpful.
  • BeanBean Posts: 8,129
    edited 2013-10-16 07:30
    I depends on what resolution you need to have.
    If GMST is in degrees, I assume you would want better resolution than that. If you want seconds(nav) then multiply everything by 3600.
    GMST(nav sec) = (1009658.226132 + 1299476.33051863032 * D) MOD 1296000
    Since you are using Julian seconds instead of days you would use:
    GMST(nav sec) = (1009658.226132 + 15.040235306928591667 * S) MOD 1296000
    That is off the top of my head. Does that final formula work ? If it does I can work out some integer math way to compute it.
    Bean
  • Mark_TMark_T Posts: 1,981
    edited 2013-10-16 08:09
    tosjduenfs wrote: »
    Well I'd first convert the formula to use seconds rather than days - ie divide the 360.98... constant by 86400, replace D by S...
    Then I'd select, as has been mentioned, a granularity for the GMST, and do that scaling for both constants (x 3600 for arc-seconds).
    You then have a formula to calculate mod 1296000 (arc-seconds per revolution). The constant used to multiply S needs to
    be approximated by a integer ratio (with at least one of numerator or denominator being full 32 bits for max precision).
    So you'll need a 32x32->64 bit multiply and a 64bit modular reduction to compute it.
    Alternatively you could choose your granularity to be 2^-32 revolutions, then the mod is for free, but you'd have to
    scale the result back to arc-seconds or whatever.
    edited 2013-10-16 08:26
    Mark_T wrote: »
    That is a great idea. That is the path I would follow.
    Bean
  • tosjduenfstosjduenfs Posts: 37
    edited 2013-10-16 09:17
    Bean wrote: »
    Bean
    This makes sense to me, it hadn't occurred to me to use arc seconds for gmst. Arc seconds would be plenty accurate for my purpose.
    edited 2013-10-16 09:47
    Mark_T wrote: »
    I'm trying to wrap my head around this one. By granularity I'm assuming you mean that 1/(2^32) is the smallest increment that GMST could vary and then the mod would be"free" because 2^32 is the maximum size of a 32 bit integer?
    Also I suppose it might be helpful to explain where it goes after this.
    After getting GMST I calculate the Local Hour Angle:
    LHA = GMST + Longitude - RA ' where LHA is degrees, Longitude is your geographical longitude also in degrees and RA is the right ascension of the object you are trying to locate also in degrees
    Then you can calculate ALT/AZ
    sin(ALT) = sin(DEC)*sin(LAT)+cos(DEC)*cos(LAT)*cos(LHA)
    cos(Az) = [sin(DEC) - sin(ALT)*sin(LAT)] / [cos(ALT)*cos(LAT)] ' where Dec is the declination of the object you are locating, ALT is the altitude calculated above, and LAT is your geographical latitude
    All of the inputs to the above equations had to be converted to radians first. Obviously Arcsin and ArcCos are applied to get the final results which are then converted back to degrees Which will be fed into a PI motor controller. Ultimately they will control two gear motors with encoders which will generate 67200 pulses per revolution of the telescope in ALT and AZ. Would it be best to work backwards from 67200?
    edited 2013-10-16 11:42
    I'm curious, what does GMST = 0 represent? Is that the transit of some particular star (which?) above Greenwich latitude 0?
    The precision of the multiplier is 13 decimal digits, around 44 bits binary. If you use lower precision, error will accumulate over time and the granularity will increase. But at 31 bits, it should still be near 0.01 second per year, and at the 24 bits (precision of the floating point significand) it should be no more than 2 seconds per year. In light of that, I don't understand your statement, "Unfortunately due to the size of the numbers involved and the lack of precision of a 32 bit floating point number my program would only generate new ALT/AZ coordinates every ~50 seconds or so (when enough time had passed that the last digit of JD changed) rather than every second as the program is written. "
    For better precision, the object F32.spin uses CORDIC for the trig functions out to full 24 bits. Float32 on the other hand uses linear interpolation to 16 bits in the 11 bit HUB table.
    edited 2013-10-16 13:19
    I will post my original code when I get home tonight so you can see the behavior I am talking about. I am using F32 now but I'm not sure If i was using it when I first had this problem so I will test that. I think GMST = 0 would mark the vernal equinox, 280.46... is the initial angle at j2000 and 360.98... is the angle the earth rotates in 24 hours.
    What I was trying to say before is that my original code takes its input from the realtimeclock object and recalculates the Julian Day Number every second and then it calculates GMST then LHA then finds the ALT/AZ coordinates of the object I'm trying to track. For example, right now it has been about 5000 days since J2000 so with float32 I can get two or three decimal places (so it seams) after 5000 so 5000.000. The best precision I can get is a thousandth of a day, and with 86400 seconds in a day you can see that when I add 1 second to 5000.000 days it will get rounded to 5000.000. Only when enough seconds have passed will it get up to 5000.001 and thus change the rest of the calculations down the line. Combine that with other rounding errors throughout the code and I only get updated alt/az coordinates about every~50seconds even though they are recalculated, with updated time, every second.
    If I could get 13 decimal digits of precision I think my code would run fine but that is not what I see when I send my variables to PST. I'll post the code when I get home tonight so you can see what I mean, maybe it will be a simple fix.
    edited 2013-10-16 17:22
    Here is my code, the ALT and AZ values only vary from the actual values by about 1/10 of a degree which is fine for my application since I will do an initial alignment of the telescope but as you can see they only change about every 50 seconds rather than every second like I need them to. In order for this to work you'll need the float to string object and the F32 object. Just load to ram and open the serial terminal.
    CON
       _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
    VAR
      long Year          'current year
      long Month         'current month
      long Day           'current day
      long Hour          'current hour
      long Minute        'current minute
      long Sec           'current second
      long DeltaT        'time diff from GMT in hours + or -
      long JD            'Julian date in decimal days
      long RaHour        'Right Ascension Hour of target
      long RaMin         'Right Ascension Minute
      long RaSec         'Right Ascension Second
      long RaDecimal     'Right Ascension decimal degrees
      long DecDeg        'Declination Degrees
      long DecMin        'Declination Minutes
      long DecSec        'Declination Seconds
      long DecDecimal    'Declination in decimal degrees
      long Alt
      long Az
      long longdeg       'longitude deg minutes second
      long longmin
      long longsec
      long longdecimal   'longitude in decimal degrees
      long latdeg        'latitude deg minutes seconds
      long latmin
      long latsec
      long latdecimal    'latitude in decimal degrees
      long GMST          'Greenwich Mean Sidereal Time
      long LHA           'Local Hour Angle
      long A             'A B C E F used in calculating Julian Date
      long B
      long C
      long E
      long F
      long D              'used in calc for GMST
    OBJ
      RTC : "RealTimeClock"
      FLT : "F32"
      FTS : "FloatString"
      PST : "Parallax Serial Terminal"
    PUB Converter
      RTC.start
      FLT.start
      PST.start(115200)
      RTC.WriteTimeReg(0,30)
      RTC.WriteTimeReg(1,52)
      RTC.WriteTimeReg(2,2)
      RTC.WriteTimeReg(3,13)
      RTC.WriteTimeReg(4,10)
      RTC.WriteTimeReg(5,13)
    repeat
      sec := FLT.Ffloat(RTC.ReadTimeReg(0))
      minute := FLT.Ffloat(RTC.ReadTimeReg(1))
      hour := FLT.Ffloat(RTC.ReadTimeReg(2))
      day := FLT.Ffloat(RTC.ReadTimeReg(3))
      month := FLT.Ffloat(RTC.ReadTimeReg(4))
      year := FLT.Fadd(FLT.Ffloat(RTC.ReadTimeReg(5)),2000.0)
      'year := 2013.0
      'month := 10.0
      'day := 13.0
      'hour := 2.0
      'minute := 52.0
      'sec := 30.0
      DeltaT := -5.0
      RaHour := 5.0
      RaMin := 34.0
      RaSec := 30.0
      DecDeg := 22.0
      DecMin := 1.0
      DecSec := 5.0
      Latdeg := 41.0
      Latmin := 15.0
      Latsec := 0.46
      Longdeg := -87.0
      Longmin := 50.0
      Longsec := 17.81
    'calculate decimal form of Right Ascension
      RaDecimal := FLT.Fmul(FLT.Fadd(FLT.Fadd(RaHour,FLT.Fdiv(RaMin,60.0)),FLT.Fdiv(RaSec,3600.0)),15.0)
    'calculate decimal form of Declination
      DecDecimal := FLT.Fadd(DecDeg,FLT.Fadd(FLT.Fdiv(DecMin,60.0),FLT.Fdiv(DecSec,3600.0)))
    'calculate decimal form of latitude
      LatDecimal := FLT.Fadd(LatDeg,FLT.Fadd(FLT.Fdiv(LatMin,60.0),FLT.Fdiv(LatSec,3600.0)))
    'calculate decimal form of longitude
      IF LongDeg < 0
        LongDeg := FLT.Fneg(LongDeg)
        LongDecimal := FLT.Fadd(LongDeg,FLT.Fadd(FLT.Fdiv(LongMin,60.0),FLT.Fdiv(LongSec,3600.0)))
        LongDecimal := FLT.Fneg(LongDecimal)
      Else
    'calculate Julian Date in decimal days since Noon Jan 1,2000, fractional parts of all multiplications and divisions are dropped in the following calculations
      IF (Month == 1.0) OR (Month == 2.0)
        Year := FLT.FSub(Year,1.0)
      ELSE
      A := FLT.Floor(FLT.Fdiv(Year,100.0))
      B := FLT.Floor(FLT.Fdiv(A,4.0))
      C := FLT.Floor(FLT.Fadd(FLT.Fsub(2.0,A),B))
      E := FLT.Floor(FLT.Fmul(365.25,FLT.Fadd(Year,4716.0)))
      F := FLT.Floor(FLT.Fmul(30.6001,FLT.Fadd(Month,1.0)))
    'Stop dropping fractions  (daylight savings time still needs to be accounted for)
      JD := FLT.Fsub(FLT.Fsub(FLT.Fadd(FLT.Fadd(FLT.Fadd(C,Day),E),F),1524.5),2451545.0)
    'Calculate Greenwich Mean Sidereal Time (GMST) GMST = 280.46061837 + 360.98564736629 * JD, D is JD plus fraction of day from hour min sec and time diff
      D := FLT.Fsub(FLT.Fadd(FLT.Fadd(FLT.Fadd(JD,FLT.Fdiv(hour,24.0)),FLT.Fdiv(minute,1440.0)),FLT.Fdiv(sec,86400.0)),FLT.Fdiv(DeltaT,24.0))
      GMST := FLT.Fmod(FLT.Fadd(280.46061837,FLT.Fmul(360.98564736629,D)),360.0)
    'Calculate Local Hour Angle LHA = GMST + Longitude - RA
      LHA := FLT.Fsub(FLT.Fadd(GMST,LongDecimal),RaDecimal)
       IF LHA < 0.0
         repeat until (LHA > 0.0) OR (LHA == 0.0)
           LHA := FLT.Fadd(LHA,360.0)
       IF LHA > 360.0
         repeat until (LHA < 360.0) OR (LHA == 360.0)
           LHA := FLT.Fsub(LHA,360.0)
    'Calculate Altitude and Azimuth values
      ALT := FLT.Degrees(FLT.Asin(FLT.Fadd(FLT.Fmul(FLT.Sin(FLT.Radians(LatDecimal)),FLT.Sin(FLT.Radians(DecDecimal))),FLT.Fmul(FLT.Fmul(FLT.Cos(FLT.Radians(LatDecimal)),FLT.Cos(FLT.Radians(DecDecimal))),FLT.Cos(FLT.Radians(LHA))))))
      AZ := FLT.Degrees(FLT.Acos(FLT.Fdiv((FLT.Fsub(FLT.Sin(FLT.Radians(DecDecimal)),FLT.Fmul(FLT.Sin(FLT.Radians(LatDecimal)),FLT.Sin(FLT.Radians(ALT))))),(FLT.Fmul(FLT.Cos(FLT.Radians(LatDecimal)),FLT.Cos(FLT.Radians(ALT)))))))
        IF FLT.Sin(FLT.radians(LHA)) > 0.0
          AZ := FLT.Fsub(360.0,AZ)
      'Repeat
       pst.str(string("sec = "))
       pst.str(FTS.FloatToString(sec))
       pst.newline
       pst.str(string("minute = "))
       pst.str(FTS.FloatToString(minute))
       pst.newline
       pst.str(string("hour = "))
       pst.str(FTS.FloatToString(hour))
       pst.newline
       pst.str(string("day = "))
       pst.str(FTS.FloatToString(day))
       pst.newline
       pst.str(string("month = "))
       pst.str(FTS.FloatToString(month))
       pst.newline
       pst.str(string("year = "))
       pst.str(FTS.FloatToString(year))
       pst.newline
       pst.str(string("Julian Day = "))
       pst.str(FTS.FloatToString(D))
       pst.Newline
       pst.str(string("GMST = "))
       pst.str(FTS.FloatToString(GMST))
       pst.Newline
       pst.str(string("LHA = "))
       pst.str(FTS.FloatToString(LHA))
       pst.Newline
       pst.str(string("AZ = "))
       pst.str(FTS.FloatToString(AZ))
       pst.newline
       pst.str(string("ALT = "))
       pst.str(FTS.FloatToString(ALT))
       waitcnt(clkfreq/1 + cnt)
       pst.clear
    RA-DEC to ALT-AZ Converter 201310131437.spin
  • davekorpidavekorpi Posts: 20
    edited 2013-10-16 22:22
    I want to do FP math too and wonder why you can not just use Floats? They are 32 bit in the shared code by Cam Thompson...
    Float32.spin...
    Here is the header...
    '' Copyright (C) 2006-2007 Parallax, Inc. All rights reserved
    '' @file Float32
    '' @target Propeller
    '' IEEE 754 compliant 32-bit floating point math routines.
    '' This object supports the basic set of floating point routines using one cog.
    '' ──Float32
    '' @author Cam Thompson, Micromega Corporation
    '' @version
    '' V1.2 - March 26, 2007
    '' - fixed Pow to handle negative base values
    '' V1.1 - Oct 5, 2006
    '' - corrected constant value for Radians and Degrees
    '' V1.0 - May 17, 2006
    '' - original version
    I want super precision math too in a fifth order polynomial I am doing and just have to wrestle with the MAXIMUM number the float can return...
    In the end can you use floats here??
  • LawsonLawson Posts: 870
    edited 2013-10-17 00:44
    tosjduenfs wrote: »
    When doing floating point addition it's easy to loose bits of precision if the inputs have different magnitudes. The given equation will suffer badly from this. (D*360.xxx >> 280.xxx) Also, Fmod( a, b) will have reduced precision when 'a' is much larger than 'b'. I'd try moving the modulus function inside the equation. Looks like this will require re-figuring the three constants of the equation though.
    If you don't care much about speed, I've written a spin only floating point library with all the same functions as F32. It's a bit more precise than F32 with Log and Exp, but isn't standards compliant with all the edge cases. (see the links to FME.spin in my signature)
    After making FME I've wondered weather it would be worth modifying it so most of the functions worked on unpacked floats pulled off of a stack? You could get ~30 bits of mantissa, expanded exponent range, plus a nice speed boost. The main cost is that floats would take 3-longs during equation evaluation. (and creating full precision constants would need some extra code)
    Marty
    edited 2013-10-17 04:48
    I haven't looked at the code you posted, but here is what I came up with for the original post:
    CON
    VAR
    OBJ
      Terminal   : "Parallax Serial Terminal"
    PUB Main
      Terminal.Start(115200)
      waitcnt(cnt+clkfreq*5) ' Wait for serial terminal
      Calc(435_179_100) ' Julian Seconds 5036.795139 * 86400
      Calc(435_179_101)
    PUB Calc(Given) | jSec, sum, temp
      jSec := Given
      Terminal.Char(13)
      Terminal.Dec(jSec)
      Terminal.Str(String(" J-Seconds", 13))
      ' sum = jSec * 49846.3718463343  ' ((360.9856473662 / 360) / 86400) * 2^32
      sum :=  jSec * 49846
      sum +=  jSec ** 1597067845
      ' sum = sum + 3346025510 ' (280.4606184 / 360) * 2^32
      sum += 3346025510
      Terminal.Dec(sum)
      Terminal.Str(String(" MOD 2^32", 13))
      ' Convert from MOD 2^32 to MOD 1296000  ' 360 * 60 * 60
      temp := sum ** 1296000
      if temp < 0
        temp += 1296000
      Terminal.Dec(temp) ' Display arc-seconds
      Terminal.Str(String(" Arc-seconds", 13))
      ' Convert from MOD 2^32 to MOD 67200
      temp := sum ** 67200
      if temp < 0
        temp += 67200
      Terminal.Dec(temp) ' Display encoder pulses
      Terminal.Str(String(" Encoder pulses", 13))
    And here is the output:
    435179100 J-Seconds
    1565451767 MOD 2^32
    472372 Arc-seconds
    24493 Encoder pulses
    435179101 J-Seconds
    1565501613 MOD 2^32
    472387 Arc-seconds
    24494 Encoder pulses
    So 1 Julian second change resulted in a 15 arc-second change.
    Bean
    edited 2013-10-17 06:24
    Thank you for taking the time to write that out Bean, I'll have to do some studying of your code. I think I follow the conversions you make but there are some things I don't quite understand. For instance:
    sum := jSec * 49846
    so sum = (jsec * 49846) + (jsec ** 1597067845)
    I'm not sure I understand the ** operation. It returns the upper 32 bits of a 32x32bit multiplication. So the upper 32 bits is the part that would normally be truncated? As in the upper 32 bits is the precision that is normally lost after the decimal? Also where does the 1597067845 come from and what exactly do these two lines accomplish?
    I wish it were just as easy as going from GMST to encoder pulses but there are also trig functions these number must pass through first.
    Again, thanks for your time.
    edited 2013-10-17 06:41
    The multiplication of jSec * 49846.3718463343 needs to be done in two parts.
    First the whole value is multiplied.
    sum := jSec * 49846
    Then the fractional part. 0.3718463343
    To multiply by a faction you take the fractional part and multiply it by 2^32 then use the ** operator.
    So 0.3718463343 * 2^32 = 1597067845
    When you multiply two 32 bit numbers you get a 64 bit result. The * operator gives the lower 32 bits, the ** gives the upper 32 bits (or the overflow).
    The 49846.3718463343 comes from converting from 360 modulus to 2^32 modulus (and also going from days to seconds as the units).
    So 360.9856473662 / 86400 because we are using seconds instead of days as the units.
    Then (360.9856473662 / 86400) / 360 to use a modulus of 1 instead of 360
    Then ((360.9856473662 / 86400) / 360) * 2^32 to use a modulus of 2^32 instead of 1
    And that gives us the 49846.3718463343
    Because the modulus is 2^32 we don't have to even think about it because all math is performed mod 2^32 by the propeller.
    As far a ** math goes, you can think of 2^32 as 1.0000000000, so to get a different modulus you just high-multiply by the modulus you desire.
    I hope that helps,
    Bean
    edited 2013-10-17 10:18
    I'm all in favor of integer math where possible. To amplify Bean's explanation of ** as a fraction...
    Think of it as multiplying two numbers together, followed by shifting right 32 bits. That is the same as dropping the low 32 bits from the result of a 32x32 mulitply.
    Z := X ** F
    is mathmatically equivalent to
    ' Z = X * Y = X * F / 232
    where Y<1 and the factor F = Y * 232
    The fraction Y has been well approximated by the fraction F/232
    If Y has both an integer part and a fractional part, they have to be done separately,
    Z := X * (integer part of Y) + X ** (fractional part of Y * 232)
    There is caveat that involves negative numbers. To use ** in this way, both factors X and F have to be positive numbers, (less than or equal to posx:2147483647) or else the Prop's twos complement math returns the wrong answer when interpreted as fractional multiply. A trick for fractions greater than or equal to 0.5 is to separate it out like this:
    Z = X * (integer part of Y) + 2*X ** (fractional part of Y/2 * 232)
    edited 2013-10-17 10:25
    Thank you Bean and Tracy I understand now, that was very helpful. I'll try putting this in my code when I get home tonight. So now I have GMST in arcseconds rather than degrees. Is there any way to use arc seconds in a trigonometric function rather than converting it back to decimal degrees or radians? For instance the next calculation is:
    ALT = arcsin[ sin(Declination) * sin(Latitude) + cos(Declination) * cos(Latitude) * cos(GMST + Longitude - Right Ascension) ]
    Where Declination, Latitude, Longitude and Right Ascension are all given values.
    edited 2013-10-17 11:34
    tosjduenfs wrote: »
    When you say "given values" do you mean the are constants ? If they are then the "sin" and "cos" can be precalculated. Leaving just a cos and arcsin function which could probably be done with CORDIC (not sure about arcsin though).
    Bean
    edited 2013-10-17 12:16
    By given I meant they are input from the user but do not change with time. They can't be precalculated since they are subject to change when the user wants to locate a different object (RA/DEC) or change their location (LAT/LONG).
    edited 2013-10-17 14:13
    The usual way to deal with arcsin(x) is via the identity,
    arcsin(x) = arctan(x / (12 - x2))
    Note that 1 is squared in the formula, a detail, but important in implementation through a process of normalization as done in floating point.
    F32 uses 24 bit CORDIC for the atan function, but it uses HUB table lookup/interpolation to 16 bits at best for sin, cos and tan. Thinking about Lawson's comments, I'm unclear on how much precision that last formula for ALT needs once you have an accurate value of GMST.
    IT WORKS!!!! Tracy you were correct, having a more accurate value of GMST was all that I needed, thank you for your insight.
    Bean, thank you so much for taking the time to write out examples and for showing me how to get an accurate value from the GMST formula.
    Not only does it work but my final values are accurate to better than 1/100th of a degree often times less than that. That is more than adequate for my application.
    Thanks again.
