How can I do a circular bit shift in propeller C
Invent-O-Doc
I know people use statements all the time like a = z << 2; , which gives a bit shift and everything that goes to the end of the variable's bit range gets chopped off, but doesn't the propeller have a PASM for a bit rotation that takes bits from one side to another in the form of a rotation???
SPIN has the '->' and '<-' operators that do this.
Is there any equivalent to this rotation command using C or C++ in Simple IDE????
The examples I see on C sites are fairly inefficient compared to an equivalent of the prop's own bit rotate.
Not in this case with propgcc it seems:
#include <stdio.h> #include <math.h> int roller (int a, int b) { return ((a << b)|(a >> (32 - b))); // To rol a, b and } int main (int argc, char* argv[]) { return (roller(3, 9)); }Compiles down to:.text .balign 4 .global _roller _roller mov r7, #32 sub r7, r1 mov r6, r0 sar r6, r7:Q shl r0, r1 mov r7, r6 or r7, r0 mov r0, r7 lret .balign 4 .global _main _main mvi r0,#1536 lretUsing: /opt/parallax/bin/propeller-elf-gcc -Os -Wall -S -o rol.s rol.cAs we see there are two shifts and an OR operation.
Similar with GCC on my PC.
Don't we have an intrinsic in propgcc to do this inline?
unsigned int rol(unsigned int a, int b) { return (a << b)|(a >> (32 - b)); } unsigned int ror(unsigned int a, int b) { return (a << (32 - b))|(a >> b); } int main() // Main function { return rol(3, 9); }with your command line I get: I believe your >> on a signed int spoils it somehow.Of course a >> on a signed number propagates the sign bit down from the top so it can never be the same as a ror. Unless some extra masking is in place to remove propagated bits.
In the rol case we would also be applying a >> to a signed number (the "(a >> (32 - b))" part. That would then require a mask to get rid of the propagated sign bits so it's probably better for the compiler to do what it does.
.text .balign 4 .global _rol _rol rol r0, r1 lret .balign 4 .global _ror _ror ror r0, r1 lret .balign 4 .global _main _main mvi r0,#1536 lretNote the use of "lret". I guess it's the same thing.
Except.. If I compile with "-mcog" then it the same as yours.
Never mind.
-Os or -O2 or -O3 work.
-O1 does not.
