Automate Aquarium Fan
I'm trying to automate some equipment and one part I can't figure out is controlling the fans. I haven't found a thermometer that seems appropriate for this task. I already have a thermometer that has the sensor (that's submersed under water) and the cable that runs to the display. Could I tear that apart to interface with my microcontroller? Right now I only have the homework board, but I'm not stuck with that one.
I'm open to suggestion as to what sensor I should be using, but if there is a better alternative (to using the one I have) I'd still like to know how that could be possible. I thought about putting one of the standard sensors pressed up against the glass, but I'm unsure how accurate that would be.
Thanks in advance.
Thanks in advance.
1) Can a regular digital thermometer be modified to "talk" to a prallax board?
2) What is the appropriate sensor to measure water temperature?
Also, it's salt-water, so I don't know that stainless-anything will work well, but I'll look into the LM34 - It may be the answer.
Industrial Control and Process Control both used an LM34 to measure temperature and a small 12V brushless fan was control using a MOSFET.
The texts are free to download and are compatible with your homework board.
Parallax still sells the Process Control Kit for $40 if you find it useful.
Not easily unless it has some sort of data port. Without a data port, you'd need to go poking around with a logic analyzer to see if you can find a data line to tap into. So basicly, if you have to ask, then no, a regular digital thermometer can't be modified to talk to a microcontroller. (Almost any device digital or not can be made to talk to a microcontroller, but it's likely to take a lot of work and there are likely easier solutions.)
Edit the original post of the thread and select "Go Advanced". There is a drop down menu to use there.
