Prop C Learn - SD Card Date - can't store the value
I modify the program from http://learn.parallax.com/propeller-c-simple-devices/sd-card-data to store the value.
The terminal display the value "val=500" that is correct.
But when I open the "test.txt" file, I see gibberish...it's "?" not the value "500".
what's wrong with my program?
#include "simpletools.h"
[COLOR=#333333][FONT=Lucida Console]int DO = 22, CLK = 23, DI = 24, CS = 25;[/FONT][/COLOR] // SD card pins on Propeller BOE
int val=500;
int main(void)
sd_mount(DO, CLK, DI, CS); // Mount SD card
FILE* fp = fopen("test.txt", "w"); // Open a file for writing
fwrite(&val, sizeof(val), 1, fp);
fclose(fp); // Close the file
fp = fopen("test.txt", "r"); // Reopen file for reading
fread(&val, 4, 1, fp);
print("val = %d\n", val);
fclose(fp);
http://www.asciitable.com/
The value 500 requires two bytes; 0x01F4. IF the bytes 0x01 and 0xF4 are stored on an SD card and later read using a text editor, then yes the character representations may be a "?" or some strange looking character.
If you want to see 500 in text editor based terminal you'll need to convert 500 to a string, save the string on the SD card or send it to the terminal. However, if you need to manipulate 500, you'll need to convert the string "500" back to an integer.
int n;
char s[80];
itoa(500, s, 10);
n = atoi(s); // convert a string to a natural number to a string.
n = strtol(s,0,10); // convert a string to a number with any base.
It is also possible to use the Simple Library #include "simpletext.h" functions "sprint" which works like sprintf and "sscan" which works like sscanf.
Don't use ANSI standard fprintf, fscanf, printf, sprintf because they are just too big for Propeller.
I forgot the text files store the character is usually ASCII code.
