Big update for DE2-115 and DE0-Nano users w/add-on boards - Page 4 — Parallax Forums
1246713
  • jmgjmg Posts: 15,198
    edited 2013-10-01 21:24
    I don't think it should be too tough to have start/stop bit generation and detection be an option for the hardware.
    Agreed. Most of the work is in finding register space, and mapping the control and flag bits.
    Also easy should be a CLKOUT option bit, even for 'async', as that (with addition of fully variable length control) then allows the P2 to use the FTDI High Speed Serial, which can manage 50MHz clock speeds.
    Streaming at 50Mbd over a standard VCP into a P2 has real appeal, and it likely to be about the Pin-limit.
    edited 2013-10-01 21:43
    jmg,
    I gave this some more thought, and I think (as long as pins can toggle at clkfreq, which Chip can tell us if it is possible)
    Most uC cannot toggle pins above 100MHz, and many limit their Serial specs to somewhat under that, to allow for Ts/Th delay effects through the relatively large and slow Pin buffers.
    assume external clock is used to shift N bits - let's say shift is on falling edge of ECLK
    once N bits are shifted, the rising edge of ECLK latches the shift register into the "Async Latch", sets internal "BITSAVAIL" flip flop
    next p2 clock rising or falling clock "Async Latch" is latched into "P2 Receive Latch", clears "BITSAVAIL"
    Sure, but you have now duplicated state machines for master and slave modes, as well as buffer registers.
    Testing is a lot more complex, and you have to hope you sliced those clock domains in the correct places.
    All of this effort, is to try to reach /1 on shift clocks ?, but I do not recall seeing any uC that offer /1 shifter clocks - /2 is common, in master mode, and even that for sub 50MHz devices. I think some allow /2 in slave, if the two chips have sync'd clocks.
    Even looking at a 'still coming' part like the 240MHz Analog Devices M4, shows a max of 50MHz spec'd for any pins, and a max of (fSCLK/4) MHz is mentioned on external clock modes. (that is still 60MHz at the pins).
    I found a NXP device, where early data mentioned 80Mbd, but 2013 data now says 52Mbd, on their SPI ports. The real world always conspires to lower practical clock speeds.
  • LawsonLawson Posts: 870
    edited 2013-10-01 21:50
    Imho, For SPI (and other high speed serial) a 32-bit wide version of the 74HC195 (or 74HC194) chip extended with an output latch or a 32-bit version of the 74HC299 would do wonders for speed. Nicer would be some muxes for clock source, which edge to clock on, where the pins connect, etc. If the shift register included a counter to (optionally) latch the register every 8-16-32 clocks and set a flag, it should deal with asynchronous bit clocks too?
    Marty
    edited 2013-10-01 23:41
    Hi Chip,
    I have just been "playing" with some of your new instructions.
    I just modified my VGA driver in Invaders to utilize the new non-polled WAITVID instruction as well as the new ESWAP8 Endian reversal.
    This made a huge impact on my drivers size and performance. It's size was reduced from 57 longs to 41 longs!
    Using ESWAP8 not only reduced the driver size but dramatically improved performance too.
    I can "nearly" get away running it at 1/16 time slot but 2/16 works great. Sure the 20MHz clock increase helped too!
    I think this shows that the real silicon @ 160MHz could easily do similar tasks in just 1/16 time slot.
    I like your new SETTASK format too.
    Very nice enhancements!
    Cheers
    Brian
    edited 2013-10-01 23:58
    ozpropdev wrote: »
    Hi Chip,
    Cheers
    Brian
    That's a great improvement!
  • SapiehaSapieha Posts: 2,964
    edited 2013-10-02 00:40
    Hi Chip.
    Have You on SERA/SERB any status register else that it set Zero/Cary flag to step over if no any character are awaiting?
    edited 2013-10-02 01:26
    ozpropdev wrote: »
    Hi Chip,
    Cheers
    Brian
    Glad it's all working. I ran the 80MHz version on my DE0-Nano and I watched it on and off for hours while I worked. It's good It has an 'attract' mode.
    That SETTASK idea was Tubular's, I believe. It's a really nice solution to variable-length task loops.
    You could use SERA/SERB to get your serial going with less overhead, too.
    edited 2013-10-02 01:28
    Sapieha wrote: »
    Hi Chip.
    We can make it do almost anything, so yes.
    I've been working on the RDSTACK/WRSTACK instructions today and I think I'll have it done tomorrow. Hopefully, I'll glean some clear direction from all this synchronous serial discussion by then and we'll have a nice and tidy solution.
    edited 2013-10-02 01:33
    Hi Chip.
    Thanks.
    That possibility will give SER function most like standard Serial port.
    Call to it --- Test if Character --- If Not step ahead --- If Character wait for it and return
    I've been working on the RDTASK/WRTASK instructions today and I think I'll have it done tomorrow. Hopefully, I'll glean some clear direction from all this synchronous serial discussion by then and we'll have a nice and tidy solution.
    edited 2013-10-02 02:00
    Hi Chip.
    I have be thinking at if it is possible Z-flag can be used as Character ready to read --- C-flag can be used as Overflow -- Income Character in buffer has be overwritten by next one (Lose of Character in stream)
    edited 2013-10-02 02:07
    Chip, That was next on my list to play with.....
    Cheers
    Brian
    edited 2013-10-02 02:25
    Sapieha wrote: »
    This might be better with 2 possible phases : Call them Skip and Wait.
    Skip jumps over, knowing it will get back again inside 1 char time. Good for small loops
    Wait, knows/expects another Char is due, and does nothing else until it arrives. Use mostly during data streams ?
    The HW needs to have 1 char of buffering, to give practical handshake times, and workable with packed data streams.
    edited 2013-10-02 03:41
    Chip: Should subr/cmpsub/incmod/decmod instructions have r=1 ?
    Here is an update to the Instruction Set for the new info from Chip.
    '' | Propeller II Instruction Set                                       v0.xx |
    '' |  Prepared by Cluso99 from information provided by Chip Gracey (Parallax) |
    '' RR20130517   first version
    '' RR20130518   add INDA/INDB & PTRA/PTRB information
    '' RR20130530   fix r s/be i for 000011 additional instructions, mul/scl i s/be r=1
    '' RR20131002   modify for new rev by Chip
    DAT
    Conditional Assembly commands
    cccc  condition        alternate
    0000  if_never         nop
    0001  if_nz_and_nc     if_a
    0010  if_z_and_nc
    0011  if_nc            if_ae
    0100  if_nz_and_c
    0101  if_nz            if_ne
    0110  if_z_ne_c
    0111  if_nz_or_nc
    1000  if_z_and_c
    1001  if_z_eq_c
    1010  if_z             if_e
    1011  if_z_or_nc
    1100  if_c             if_b
    1101  if_nz_or_c
    1110  if_z_or_c        if_be
    1111  if_always        (default)
    INDA & INDB (Cog addresses $1F6 & $1F7)...
    .....                                 (Note: Instructions using indirection ALWAYS execute      )
    opcode zcri cccc --dest--- -source--  (      Therefore, cccc specify none/postinc/postdec/preinc)
    ------ ---- 00xx 111110110 ---------  Dest = INDA
    ------ ---- 01xx 111110110 ---------  Dest = INDA++
    ------ ---- 10xx 111110110 ---------  Dest = INDA--
    ------ ---- 11xx 111110110 ---------  Dest = ++INDA
    ------ ---- 00xx 111110111 ---------  Dest = INDB
    ------ ---- 01xx 111110111 ---------  Dest = INDB++
    ------ ---- 10xx 111110111 ---------  Dest = INDB--
    ------ ---- 11xx 111110111 ---------  Dest = ++INDB
    ------ ---0 xx00 --------- 111110110  Srce = INDA
    ------ ---0 xx01 --------- 111110110  Srce = INDA++
    ------ ---0 xx10 --------- 111110110  Srce = INDA--
    ------ ---0 xx11 --------- 111110110  Srce = ++INDA
    ------ ---0 xx00 --------- 111110111  Srce = INDB
    ------ ---0 xx01 --------- 111110111  Srce = INDB++
    ------ ---0 xx10 --------- 111110111  Srce = INDB--
    ------ ---0 xx11 --------- 111110111  Srce = ++INDB
    PTR (hub address) & RD/WR-QUAD/LONG/WORD/BYTE-C Instructions    (i=1 uses PTRx)
                               ┌─────────── 0 = PTRA              1 = PTRB
                               │┌────────── 0 = PTRx no update    1 = PTRx updated
                               ││┌───────── 0 = PTRx+Index*Scale  1 = PTRx (post modify)
                               │││   ┌───── Index -32..+31 (nnnnnn = -Index, NNNNNN = +Index)
                               │││   │      Scale is 1=Byte, 2=Word, 4=Long, 16=Quad
                               supnnnnnn
    opcode zcri cccc --dest--- -source--    Expression       Uses Initial value    Final value
    ------ ---1 ---- --------- 000000000    PTRA             PTRA
    ------ ---1 ---- --------- 011000000    PTRA++           PTRA                  PTRA += Scale
    ------ ---1 ---- --------- 011111111    PTRA--           PTRA                  PTRA -= Scale
    ------ ---1 ---- --------- 010000001    ++PTRA           PTRA + Scale          PTRA += Scale          (ie Index = +1)
    ------ ---1 ---- --------- 010111111    --PTRA           PTRA - Scale          PTRA -= Scale          (ie Index = -1)
    ------ ---1 ---- --------- 000NNNNNN    PTRA[Index]      PTRA + Index*Scale                           (ie Index = +NNNNNN)
    ------ ---1 ---- --------- 011NNNNNN    PTRA++[Index]    PTRA                  PTRA += Index*Scale    (ie Index = +NNNNNN)
    ------ ---1 ---- --------- 011nnnnnn    PTRA--[Index]    PTRA                  PTRA -= Index*Scale    (ie Index = -nnnnnn)
    ------ ---1 ---- --------- 010NNNNNN    ++PTRA[Index]    PTRA + Index*Scale    PTRA += Index*Scale    (ie Index = +NNNNNN)
    ------ ---1 ---- --------- 010nnnnnn    --PTRA[Index]    PTRA - Index*Scale    PTRA -= Index*Scale    (ie Index = -nnnnnn)
    ------ ---1 ---- --------- 100000000    PTRB             PTRB
    ------ ---1 ---- --------- 111000000    PTRB++           PTRB                  PTRB += Scale
    ------ ---1 ---- --------- 111111111    PTRB--           PTRB                  PTRB -= Scale
    ------ ---1 ---- --------- 110000001    ++PTRB           PTRB + Scale          PTRB += Scale          (ie Index = +1)
    ------ ---1 ---- --------- 110111111    --PTRB           PTRB - Scale          PTRB -= Scale          (ie Index = -1)
    ------ ---1 ---- --------- 100NNNNNN    PTRB[Index]      PTRB + Index*Scale                           (ie Index = +NNNNNN)
    ------ ---1 ---- --------- 111NNNNNN    PTRB++[Index]    PTRB                  PTRB += Index*Scale    (ie Index = +NNNNNN)
    ------ ---1 ---- --------- 111nnnnnn    PTRB--[Index]    PTRB                  PTRB -= Index*Scale    (ie Index = -nnnnnn)
    ------ ---1 ---- --------- 110NNNNNN    ++PTRB[Index]    PTRB + Index*Scale    PTRB += Index*Scale    (ie Index = +NNNNNN)
    ------ ---1 ---- --------- 110nnnnnn    --PTRB[Index]    PTRB - Index*Scale    PTRB -= Index*Scale    (ie Index = -nnnnnn)
    Instuction set for Propeller II
    -opc--  opcode-  operand zcri cccc    opcode-  operand zcri cccc    opcode-  operand zcri cccc
    000000  wrbyte   D,S/PTR 000p ----    rdbyte   D,S/PTR -01p ----    rdbytec  D,S/PTR -11p ----
    000001  wrword   D,S/PTR 000p ----    rdword   D,S/PTR -01p ----    rdwordc  D,S/PTR -11p ----
    000010  wrlong   D,S/PTR 000p ----    rdlong   D,S/PTR -01p ----    rdlongc  D,S/PTR -11p ----
    000011  coginit  D,S     ---0 ----  ───── *** see table for opcode 000011 i=1 below ***
    000100  mul      D,[#]S  --1- ----  ───────────────────────────┐
    000101  scl      D,[#]S  --1- ----  ─────────────────────────┐ │  ┌ setacca  D,[#]S  000- ----
    000110  enc      D,[#]S  ---- ----                           │ └──┤ setaccb  D,[#]S  010- ----
    000111  jmpret   D,[#]S  ---- ----    call/ret               │    │ maca     D,[#]S  100- ----
    001000  ror      D,[#]S  ---- ----                           │    └ macb     D,[#]S  110- ----
    001001  rol      D,[#]S  ---- ----                           │
    001010  shr      D,[#]S  ---- ----                           │    ┌ movf     D,[#]S  000- ----
    001011  shl      D,[#]S  ---- ----                           └────┤ qsincos  D,[#]S  010- ----
    001100  rcr      D,[#]S  ---- ----                                │ qarctan  D,[#]S  100- ----
    001101  rcl      D,[#]S  ---- ----                                └ qrotate  D,[#]S  110- ----
    001110  sar      D,[#]S  ---- ----
    001111  rev      D,[#]S  ---- ----
    010000  mins     D,[#]S  ---- ----
    010001  maxs     D,[#]S  ---- ----
    010010  min      D,[#]S  ---- ----
    010011  max      D,[#]S  ---- ----
    010100  movs     D,[#]S  ---- ----
    010101  movd     D,[#]S  ---- ----
    010110  movi     D,[#]S  ---- ----
    010111  jmpretd  D,[#]S  ---- ----    calld/retd
    011000  and      D,[#]S  ---- ----    test
    011001  andn     D,[#]S  ---- ----    testn
    011010  or       D,[#]S  ---- ----                                ┌ setinda  #S      0000 0001
    011011  xor      D,[#]S  ---- ----                                │ setinda  S       0000 0011
    011100  muxc     D,[#]S  ---- ----                                │ setindb  #D      0000 0100
    011101  muxnc    D,[#]S  ---- ----                                │ setindb  D       0000 1100
    011110  muxz     D,[#]S  ---- ----                                │ setinds  #D,#S   0000 0101
    011111  muxnz    D,[#]S  ---- ----                                │ setinds  #D,S    0000 0111
    100000  add      D,[#]S  ---- ----                 ┌──────────────┤ setinds  D,#S    0000 1101
    100001  sub      D,[#]S  ---- ----    cmp          │              └ setinds  D,S     0000 1111
    100010  addabs   D,[#]S  ---- ----                 │
    100011  subabs   D,[#]S  ---- ----                 │              ┌ fixinda  #D,#S   0000 0001
    100100  sumc     D,[#]S  ---- ----                 │ ┌────────────┤ fixindb  #D,#S   0000 0100
    100101  sumnc    D,[#]S  ---- ----                 │ │            └ fixinds  #D,#S   0000 0101
    100110  sumz     D,[#]S  ---- ----                 │ │
    100111  sumnz    D,[#]S  ---- ----                 │ │ ┌────────── cfgpins  D,[#]S  000- ----
    101000  mov      D,[#]S  ---- ----                 │ │ │
    101001  neg      D,[#]S  ---- ----                 │ │ │ ┌──────── waitvid  D,[#]S  000- ----
    101010  abs      D,[#]S  ---- ----                 │ │ │ │
    101011  absneg   D,[#]S  ---- ----                 │ │ │ │        ┌ ijz      D,[#]S  00-- ---
    101100  negc     D,[#]S  ---- ----                 │ │ │ │        │ ijzd     D,[#]S  01-- ---
    101101  negnc    D,[#]S  ---- ----                 │ │ │ │ ┌──────┤ ijnz     D,[#]S  10-- ---
    101110  negz     D,[#]S  ---- ----                 │ │ │ │ │      └ ijnzd    D,[#]S  11-- ---
    101111  negnz    D,[#]S  ---- ----                 │ │ │ │ │
    110000  cmps     D,[#]S  ---- ----                 │ │ │ │ │      ┌ djz      D,[#]S  00-- ---
    110001  cmpsx    D,[#]S  ---- ----                 │ │ │ │ │      │ djzd     D,[#]S  01-- ---
    110010  addx     D,[#]S  ---- ----                 │ │ │ │ │ ┌────┤ djnz     D,[#]S  10-- ---
    110011  subx     D,[#]S  ---- ----                 │ │ │ │ │ │    └ djnzd    D,[#]S  11-- ---
    110100  adds     D,[#]S  ---- ----                 │ │ │ │ │ │
    110101  subs     D,[#]S  ---- ----                 │ │ │ │ │ │    ┌ tjz      D,[#]S  000- ---
    110110  addsx    D,[#]S  ---- ----                 │ │ │ │ │ │    │ tjzd     D,[#]S  010- ---
    110111  subsx    D,[#]S  ---- ----                 │ │ │ │ │ │    │ tjnz     D,[#]S  100- ---
    111000  subr     D,[#]S  --1- ----  ─ cmpr ────────┘ │ │ │ │ │    │ tjnzd    D,[#]S  110- ---
    111001  cmpsub   D,[#]S  --1- ----  ─────────────────┘ │ │ │ │    │ jp       D,[#]S  001- ---
    111010  incmod   D,[#]S  --1- ----  ───────────────────┘ │ │ │    │ jpd      D,[#]S  011- ---
    111011  decmod   D,[#]S  --1- ----  ─────────────────────┘ │ │ ┌──┤ jnp      D,[#]S  101- ---
    111100  ij***    D,[#]S  **-- ----  ───────────────────────┘ │ │  └ jnpd     D,[#]S  111- ---
    111101  dj***    D,[#]S  **-- ----  ─────────────────────────┘ │
    111110  tj***    D,[#]S  ***- ----  ───────────────────────────┘
    111111  waitcnt  D,[#]S  0--- ----    waitpeq  D,[#]S  1-0- ----    waitpne  D,[#]S  1-1- ----
    Additional instructions for opcode=000011 with i=1 (coginit has i=0)
    -source--  opcode-  operand --dest--- zcri cccc    opcode-  operand --dest--- zcri cccc    opcode-  operand --dest--- zcri cccc
    000000000  clkset   D       --------- ---1 ----
    000000001  cogid    D       --------- ---1 ----
    000000010 (coginit) D       --------- ---1 ----
    000000011  cogstop  D       --------- ---1 ----
    000000100  locknew  D       --------- ---1 ----
    000000101  lockret  D       --------- ---1 ----
    000000110  lockset  D       --------- ---1 ----
    000000111  lockclr  D       --------- ---1 ----
    000001000  serina   D       --------- ---1 ----
    000001001  serinb   D       --------- ---1 ----
    000001010  pushzc   D       --------- ---1 ----
    000001011  popzc    D       --------- ---1 ----
    000001100  subcnt   D       --------- --11 ----    cmpcnt   D       --------- --01 ----
    000001101  getcnt   D       --------- --11 ----    passcnt  D       --------- --01 ----
    000001110  getacca  D       --------- ---1 ----
    000001111  getaccb  D       --------- ---1 ----
    000010000  getlfsr  D       --------- ---1 ----
    000010001  gettops  D       --------- --11 ----    polvid           --------- -101 ----
    000010010  getptra  D       --------- --11 ----    polctra          --------- -101 ----
    000010011  getptrb  D       --------- --11 ----    polctrb          --------- -101 ----
    000010100  getpix   D       --------- --11 ----
    000010101  getspd   D       --------- --11 ----    chkspd           000000000 --01 ----
    000010110  getspa   D       --------- --11 ----    chkspa           000000000 --01 ----
    000010111  getspb   D       --------- --11 ----    chkspb           000000000 --01 ----
    000011000  popar    D       --------- --11 ----
    000011001  popbr    D       --------- --11 ----
    000011010  popa     D       --------- --11 ----
    000011011  popb     D       --------- --11 ----
    000011100  reta             000000000 --01 ----
    000011101  retb             000000000 --01 ----
    000011110  retad            000000000 --01 ----
    000011111  retbd            000000000 --01 ----
    000100000  decod2   D       --------- ---1 ----
    000100001  decod3   D       --------- ---1 ----
    000100010  decod4   D       --------- ---1 ----
    000100011  decod5   D       --------- ---1 ----
    000100100  blmask   D       --------- ---1 ----
    000100101  not      D       --------- ---1 ----
    000100110  onecnt   D       --------- ---1 ----
    000100111  zercnt   D       --------- ---1 ----
    000101000  incpat   D       --------- ---1 ----
    000101001  decpat   D       --------- ---1 ----
    000101010  bingry   D       --------- ---1 ----
    000101011  grybin   D       --------- ---1 ----
    000101100  mergew   D       --------- ---1 ----
    000101101  splitw   D       --------- ---1 ----
    000101110  eswap4   D       --------- ---1 ----
    000101111  eswap8   D       --------- ---1 ----
    000110000  getmull  D       --------- ---1 ----
    000110001  getmulh  D       --------- ---1 ----
    000110010  getdivq  D       --------- ---1 ----
    000110011  getdivr  D       --------- ---1 ----
    000110100  getsqrt  D       --------- ---1 ----
    000110101  getqx    D       --------- ---1 ----
    000110110  getqy    D       --------- ---1 ----
    000110111  getqz    D       --------- ---1 ----
    000111000  getphsa  D       --------- ---1 ----
    000111001  getphza  D       --------- ---1 ----
    000111010  getcosa  D       --------- ---1 ----
    000111011  getsina  D       --------- ---1 ----
    000111100  getphsb  D       --------- ---1 ----
    000111101  getphzb  D       --------- ---1 ----
    000111110  getcosb  D       --------- ---1 ----
    000111111  getsinb  D       --------- ---1 ----
    001iiiiii  repd     #i      111111111 -001 ----    repd     D/#n,#i nnnnnnnnn -0#1 ----    reps     #n,#i   nnnnnnnnn n111 nnnn
    01000tttt  jmptask  D/#n,#t nnnnnnnnn --#1 ----
    0100100--  -spare-          nnnnnnnnn --#1 ----
    010010100  settask  D/#n    nnnnnnnnn --#1 ----
    010010101  clracca          000000000 --01 ----
    010010110  clraccb          000000000 --01 ----
    010010111  clraccs          000000000 --01 ----
    010011000  cachex           000000000 --01 ----
    010011001  saracca  D/#n    ---nnnnnn --#1 ----
    010011010  saraccb  D/#n    ---nnnnnn --#1 ----
    010011011  saraccs  D/#n    ---nnnnnn --#1 ----
    010011100  serouta  D/#n    nnnnnnnnn --#1 ----
    010011101  seroutb  D/#n    nnnnnnnnn --#1 ----
    010011110  setxch   D/#n    nnnnnnnnn --#1 ----
    010011111  setxfr   D/#n    nnnnnnnnn --#1 ----
    010100000  nopx     D/#n    nnnnnnnnn --#1 ----
    010100001  setzc    D/#n    nnnnnnnnn --#1 ----
    010100010  setspa   D/#n    -nnnnnnnn --#1 ----
    010100011  setspb   D/#n    -nnnnnnnn --#1 ----
    010100100  addspa   D/#n    -nnnnnnnn --#1 ----
    010100101  addspb   D/#n    -nnnnnnnn --#1 ----
    010100110  subspa   D/#n    -nnnnnnnn --#1 ----
    010100111  subspb   D/#n    -nnnnnnnn --#1 ----
    010101000  pushar   D/#n    nnnnnnnnn --#1 ----
    010101001  pushbr   D/#n    nnnnnnnnn --#1 ----
    010101010  pusha    D/#n    nnnnnnnnn --#1 ----
    010101011  pushb    D/#n    nnnnnnnnn --#1 ----
    010101100  calla    D/#n    nnnnnnnnn --#1 ----
    010101101  callb    D/#n    nnnnnnnnn --#1 ----
    010101110  callad   D/#n    nnnnnnnnn --#1 ----
    010101111  callbd   D/#n    nnnnnnnnn --#1 ----
    010110000  wrquad   D/PTR   supiiiiii --p1 ----
    010110001  rdquad   D/PTR   supiiiiii -0p1 ----     rdquadc  D/PTR   supiiiiii -1p1 ----
    010110010  setptra  D/#n    nnnnnnnnn --#1 ----
    010110011  setptrb  D/#n    nnnnnnnnn --#1 ----
    010110100  addptra  D/#n    nnnnnnnnn --#1 ----
    010110101  addptrb  D/#n    nnnnnnnnn --#1 ----
    010110110  subptra  D/#n    nnnnnnnnn --#1 ----
    010110111  subptrb  D/#n    nnnnnnnnn --#1 ----
    010111000  setpix   D/#n    nnnnnnnnn --#1 ----
    010111001  setpixu  D/#n    nnnnnnnnn --#1 ----
    010111010  setpixv  D/#n    nnnnnnnnn --#1 ----
    010111011  setpixz  D/#n    nnnnnnnnn --#1 ----
    010111100  setpixa  D/#n    nnnnnnnnn --#1 ----
    010111101  setpixr  D/#n    nnnnnnnnn --#1 ----
    010111110  setpixg  D/#n    nnnnnnnnn --#1 ----
    010111111  setpixb  D/#n    nnnnnnnnn --#1 ----
    011000000  setmula  D/#n    nnnnnnnnn -1#1 ----    setmulu  D/#n    nnnnnnnnn -0#1 ----
    011000001  setmulb  D/#n    nnnnnnnnn --#1 ----
    011000010  setdiva  D/#n    nnnnnnnnn -1#1 ----    setdivu  D/#n    nnnnnnnnn -0#1 ----
    011000011  setdivb  D/#n    nnnnnnnnn --#1 ----
    011000100  setsqrh  D/#n    nnnnnnnnn --#1 ----
    011000101  setsqrl  D/#n    nnnnnnnnn --#1 ----
    011000110  setqi    D/#n    nnnnnnnnn --#1 ----
    011000111  setqz    D/#n    nnnnnnnnn --#1 ----
    011001000  qlog     D/#n    nnnnnnnnn --#1 ----
    011001001  qexp     D/#n    nnnnnnnnn --#1 ----
    011001010  setf     D/#n    nnnnnnnnn --#1 ----
    011001011  setskip  D/#n    nnnnnnnnn --#1 ----
    011001100  cfgdac0  D/#n    -------nn --#1 ----
    011001101  cfgdac1  D/#n    -------nn --#1 ----
    011001110  cfgdac2  D/#n    -------nn --#1 ----
    011001111  cfgdac3  D/#n    -------nn --#1 ----
    011010000  setdac0  D/#n    nnnnnnnnn --#1 ----
    011010001  setdac1  D/#n    nnnnnnnnn --#1 ----
    011010010  setdac2  D/#n    nnnnnnnnn --#1 ----
    011010011  setdac3  D/#n    nnnnnnnnn --#1 ----
    011010100  cfgdacs  D/#n    -nnnnnnnn --#1 ----
    011010101  setdacs  D/#n    nnnnnnnnn --#1 ----
    011010110  getp     D/#n    --nnnnnnn --#1 ----
    011010111  getnp    D/#n    --nnnnnnn --#1 ----
    011011000  offp     D/#n    --nnnnnnn --#1 ----
    011011001  notp     D/#n    --nnnnnnn --#1 ----
    011011010  clrp     D/#n    --nnnnnnn --#1 ----
    011011011  setp     D/#n    --nnnnnnn --#1 ----
    011011100  setpc    D/#n    --nnnnnnn --#1 ----
    011011101  setpnc   D/#n    --nnnnnnn --#1 ----
    011011110  setpz    D/#n    --nnnnnnn --#1 ----
    011011111  setpnz   D/#n    --nnnnnnn --#1 ----
    011100000  setcog   D/#n    -----nnnn --#1 ----
    011100001  setmap   D/#n    ---nnnnnn --#1 ----
    011100010  setquad  D/#n    nnnnnnnnn -0#1 ----    setquaz  D/#n    nnnnnnnnn -1#1 ----
    011100011  setport  D/#n    --nn----- --#1 ----
    011100100  setpora  D/#n    --nn----- --#1 ----
    011100101  setporb  D/#n    --nn----- --#1 ----
    011100110  setporc  D/#n    --nn----- --#1 ----
    011100111  setpord  D/#n    --nn----- --#1 ----
    011101000  setpera  D/#n    nnnnnnnnn --#1 ----
    011101001  setsera  D/#n    nnnnnnnnn --#1 ----
    011101010  setperb  D/#n    nnnnnnnnn --#1 ----
    011101011  setserb  D/#n    nnnnnnnnn --#1 ----
    011101100  setvid   D/#n    nnnnnnnnn --#1 ----
    011101101  setvidy  D/#n    nnnnnnnnn --#1 ----
    011101110  setvidi  D/#n    nnnnnnnnn --#1 ----
    011101111  setvidq  D/#n    nnnnnnnnn --#1 ----
    011110000  setctra  D/#n    nnnnnnnnn --#1 ----
    011110001  setwava  D/#n    nnnnnnnnn --#1 ----
    011110010  setfrqa  D/#n    nnnnnnnnn --#1 ----
    011110011  setphsa  D/#n    nnnnnnnnn --#1 ----
    011110100  addphsa  D/#n    nnnnnnnnn --#1 ----
    011110101  subphsa  D/#n    nnnnnnnnn --#1 ----
    011110110  synctra          nnnnnnnnn --01 ----
    011110111  capctra          nnnnnnnnn --01 ----
    011111000  setctrb  D/#n    nnnnnnnnn --#1 ----
    011111001  setwavb  D/#n    nnnnnnnnn --#1 ----
    011111010  setfrqb  D/#n    nnnnnnnnn --#1 ----
    011111011  setphsb  D/#n    nnnnnnnnn --#1 ----
    011111100  addphsb  D/#n    nnnnnnnnn --#1 ----
    011111101  subphsb  D/#n    nnnnnnnnn --#1 ----
    011111110  synctrb          nnnnnnnnn --01 ----
    011111111  capctrb          nnnnnnnnn --01 ----
    1000bbbbb  isob     D,#b    --------- ---1 ----
    1001bbbbb  notb     D,#b    --------- ---1 ----
    1010bbbbb  clrb     D,#b    --------- ---1 ----
    1011bbbbb  setb     D,#b    --------- ---1 ----
    1100bbbbb  setbc    D,#b    --------- ---1 ----
    1101bbbbb  setbnc   D,#b    --------- ---1 ----
    1110bbbbb  setbz    D,#b    --------- ---1 ----
    1111bbbbb  setbnz   D,#b    --------- ---1 ----
    P2_Instructions_20131002a.spin
    Note replaced with "a" version.
  • SeairthSeairth Posts: 2,474
    edited 2013-10-02 04:19
    What if P2 only supported SPI master mode? I suspect that master mode will be used the majority of the time. And we would still have the UART for chip-to-chip communication. This might simplify the implementation:
    • Set phase, polarity, bit order, MISO, MOSI, CLK, divider
    • Allow only 8-bit frames (larger can be handled in software)
    • SEROUTx outputs without start bit, ID, or stop bit
    • SERINx reads buffered input (captured on the appropriate clock edge during SEROUTx)
    • CS is handled in software (i.e. SPI hardware has no knowledge of CS)
    The biggest difference I see here is that the receiver is now tied to the transmitter in a way that the UART isn't.
    edited 2013-10-02 04:32
    Hi Cluso.
    Have You made that changes to Debugger ?
    Cluso99 wrote: »
    DAT
    0000  if_never         nop
    0010  if_z_and_nc
    0011  if_nc            if_ae
    0100  if_nz_and_c
    0101  if_nz            if_ne
    0110  if_z_ne_c
    0111  if_nz_or_nc
    1000  if_z_and_c
    1001  if_z_eq_c
    1010  if_z             if_e
    1011  if_z_or_nc
    1100  if_c             if_b
    1101  if_nz_or_c
                               supnnnnnn
    edited 2013-10-02 04:37
    Sapieha: No, not yet.
  • evanhevanh Posts: 16,997
    edited 2013-10-02 05:05
    Seairth wrote: »
    [*] SERINx reads buffered input (captured on the appropriate clock edge during SEROUTx)
    Master only does sound like a decent compromise. After all, the main reason for wanting SPI is to connect small pin count peripheral chips. I believe raw USB or Ethernet has been shot down on the basis of needing complex framing in the hardware, right?
    edited 2013-10-02 05:28
    I'm good with SPI master only, same reasons as evanh.
    C.W.
    edited 2013-10-02 06:12
    I can see the advantage of the FTDI High Speed Serial mode...
    50Mbaud is very attractive for communicating with USB hosts with an FTDI - thanks for pointing it out, I had not run across that before.
    jmg wrote: »
    edited 2013-10-02 06:18
    Thanks jmg.
    Real world limits can be a pain :)
    I totally agree that it is not worth a lot of pain to reach clkfreq/1 on serial, looks like my thought experiments under estimated the level of effort required to implement/test it.
    /2 would still be nice if the level of effort required was reasonable, however your examples below suggest it too may require too much effort.
    jmg wrote: »
    edited 2013-10-02 06:24
    +1
    Fast SPI master is far more important than fast slave, so if it easier to only support fast master, it really is a good compromise.
    Seairth wrote: »
    edited 2013-10-02 06:55
    Sapieha wrote: »
    Hi Cluso.
    FYI, there are more opcodes that have changed than are listed in Chip's message at the head of this thread. I wrote a program to compare Chip's opcode table with the one in PropGCC and found numerous other differences.
    edited 2013-10-02 07:14
    Seairth,
    I have to strongly disagree with that assumption.
    The Prop and Prop II especially can make excellent peripheral chips to larger systems. Say an ARM board running Linux. Very common systems now a days.
    As such SPI slave is very important as it is far easier to operate the host end as a master. Nobody is going to want to start writing Linux device drivers to use the SPI interface as a slave device.
    edited 2013-10-02 07:22
    evanh,
    Bill,
    Again, I have to say: slave is important. Consider you want to connect a Prop to an ARM machine or some bigger system? The Prop is the peripheral chip. Fast SPI slave woudld be a great way to sell the Prop as periheral device.
    If it's just not practcal to do then so be it. I just think SLAVE can be more important than MASTER.
    edited 2013-10-02 07:37
    Heater. wrote: »
    It's not ideal, but SPI slave can still be done entirely in software. At the end of the day, I'd rather have fast hardware SPI master support than no hardware SPI support at all. Also, many chips (including ARM, Microchip, AVR) support TTL UARTs that should be able to work with the existing P2 UART functionality.
    edited 2013-10-02 07:52
    Heater,
    You are right, I had my prop-centric hat on. Fast slave is also very important, as fast as is consistent with not requiring too great an effort.
    Just for yucks, let's figure out the fastest possible externally clocked software SPI slave code - I'll start here:
    getspibyte  ' wait for rising spiclk, sample miso
        waitpeq    clkpin, clkpin
        shr        pinsa,#miso wc,nr
        waitpne    clkpin, clkpin
        rlc        spibyte, #1
        ' 7 more copies of above, with loop unrolled we avoid loop overhead
    getspibyte_ret
        ret
    Prop2_Docs.txt does not give the minimum number of cycles for waitpeq.
    1 cycle wait*: 4 clocks per bit in ideal circumstances (which are not likely), and invalid results if spiclk is too fast.
    2 cycle wat*: 6 clocks per bit
    general formula: W*2+2 clocks minimum for one SPI clock, where W is the minimum wait* time
    external clock software receive:
    26.6Mbps @ 160Mhz - assuming W=2 is feasible
    20.0Mbps @ 160Mhz - assuming W=3 is feasible
    16.0Mbps @ 160Mhz - assuming W=4 is feasible
    13.3Mbps @ 160Mhz - assuming W=5
    external clock hardware receive:
    80.0Mbps @ 160Mhz, if clkfreq/2 is possible
    53.3Mbps @ 160Mhz, at clkfreq/3
    40.0Mbps @ 160Mhz, at clkfreq/4
    Conclusions:
    - hardware externally clocked SPI slave is much faster than software based externally clocked SPI slave
    - hardware SPI slave can run as a task in a cog
    - software SPI slave needs a whole cog
    Ok heater, you got me - much nicer to be a fast hardware peripheral to an external processor (than a slow one)
    Heater. wrote: »
    Bill,
    edited 2013-10-02 08:02
    I think this is a key observation. This means that these simple peripherals like UART, I2C, SPI, etc don't have to consume an entire COG. They can be combined with some higher level logic that runs in another thread. I think this makes the Propeller far more useful. You can use all 8 COGs to partition your application without giving up any to handle the tasks that are supported by custom hardware on other microcontrollers.
    Seairth,
    No doubt true. But...
    There are many systems out there can can act as MASTER to any slave peripherals. Prop II as a SLAVE peripheral would be perfect. It's not always possible to create that software on the MASTER end.
    Two examples:
    1) Any Linux based system. That's a lot. Linux has no SLAVE side driver. I am certainly not up to creating one. It would be great to be able to attach a Prop II as a peripheral to a Beagle Bone, Raspberry Pi and many others.
    2) The Espruino has SPI MASTER support for attaching peripheral chips. Again, anyone want to create that SLAVE side driver.
    Philosophically the Prop is the slave in these situations so it makes sense to have SPI SLAVE support.
    Anyway as I said, if HOST only is easier and SLAVE is impractical, so be it.
    We have to stop messing with the PII design at some point:)
    edited 2013-10-02 08:13
    Heater. wrote: »
    We need to keep that in mind.
    I agree that SPI slave opens up some really nice use cases, but at some point we are going to ask for one thing too many and end up getting less than we could have had...
    I can see Chip saying he has Slave SPI implemented and then someone will chime in with a request for yet another protocol to be supported and...
    C.W.
    edited 2013-10-02 08:18
    True
    ctwardell wrote: »
    C.W.
