fsrw isn't flushing all data
Hi,
I'm trying to write CSV to a log file on an SD card, and I'm finding that the file ends with several 512-byte blocks of nulls rather than the correct data.
I'm making a GPS data-logger based on the Skytraq Venus 6 chipset, configured to binary mode. My serial-handling cog calls proc_msg when it finds a complete navigation message from the GPS. 'Ser' is a FullDuplexSerial4port object with port 0 connected to the GPS and port 1 going to the upstream USB port.
I have a button attached to pin 22 with a simple hardware debounce circuit, and an LED on pin 23 that's handled by a 3rd cog.
So, I turn on the board, and my LED turns green. I wait until the GPS lock LED starts blinking and then I press the button such that my LED starts blinking green. After 10-15 seconds, I press the button for several seconds, and when I release, the LED turns off. I wait a few seconds in case the SD card needs to flush itself then depower the board, put the SD card into the computer, and get the attached file. The first 512 bytes of the file are correct, then it's nulls up until the proper length of the file, where it ends in $0d, $0a.
Am I doing something wrong that the file isn't getting flushed properly?
PUB run_button | evt, last_state, last_time, failed
evt := \sdfat.mount_explicit(24, 25, 26, 27) ' SD card on pins 24-27
if evt
led := LED_RED
ser.str(1, string("Mount error "))
Dec(evt, 0)
ser.Tx(1, $0d)
else
led := LED_GREEN
ser.str(1, string("Mount succeeded", $0d))
repeat
evt := 0
if last_state and not ina[22]
' Button pressed
last_time := cnt
evt := 1
if ina[22] and not last_state
' Button released
last_time := cnt - last_time
evt := 2
last_state := ina[22]
if evt == 2
if last_time > (clkfreq << 1)
' Button held at least two seconds
led := LED_GREEN_FAST_BLINK
led := LED_OFF
sdfat.unmount
elseif last_time > (clkfreq >> 3)
' Button held at least an eigth of a second - real press
if led =< LED_YELLOW
' Not in a state we can do anything about
else
if led == LED_GREEN
failed := \sdfat.popen(string("log.csv"), "a")
if failed
led := LED_RED
led := LED_GREEN_BLINK
elseif led == LED_GREEN_BLINK
sdfat.pclose
led := LED_GREEN
if good and (led == LED_GREEN_BLINK)
Dec(week, 1)
sdfat.pputc(",")
Dec(centiseconds, 1)
sdfat.pputc(",")
Dec(lat, 1)
sdfat.pputc(",")
Dec(lon, 1)
sdfat.pputc(",")
Dec(alt, 1)
sdfat.pputc($0d)
sdfat.pputc($0a)
good := 0
PRI proc_msg | i
'ser.str(1, string("Got GPS: la"))
' Week is a 16 bit value, so need to 0-fill it
' Other values are 32 bits, so any existing data gets shifted out.
week := 0
repeat i from 7 to 8
week <<= 8
week |= gps_string[i]
repeat i from 9 to 12
centiseconds <<= 8
centiseconds |= gps_string[i]
repeat i from 13 to 16
lat <<= 8
lat |= gps_string[i]
repeat i from 17 to 20
lon <<= 8
lon |= gps_string[i]
repeat i from 25 to 28
alt <<= 8
alt |= gps_string[i]
good := 1
Dec(week, 0)
Ser.Tx(1, ",")
Dec(centiseconds, 0)
Ser.Tx(1, ",")
Dec(lat, 0)
Ser.Tx(1, ",")
Dec(lon, 0)
Ser.Tx(1, ",")
Dec(alt, 0)
Ser.Tx(1, $0d)
* This also includes the case of violent motion disrupting the contacts on the card.
I've not read any of the code but I'd say that is a bit of an indication that you are feeding nulls into the file.
elseif led == LED_GREEN_BLINK if good == 0 led := LED_GREEN_FAST_BLINK sdfat.pclose led := LED_GREEN1. finish any writing of data so you have a complete data element
2. close file (includes flushing of data)
3. unmount card
I don't follow your logic in your code as to how this happens. But maybe it's just me... :-)
So, calling unmount closes the file anyway.
repeat 1000 Dec(week, 1) sdfat.pputc(",") Dec(centiseconds, 1) sdfat.pputc(",") Dec(lat, 1) sdfat.pputc(",") Dec(lon, 1) sdfat.pputc(",") Dec(alt, 1) sdfat.pputc($0d) sdfat.pputc($0a)This loop should be preceded by mount/popen calls and followed by pclose/unmount calls. This is to establish whether there is an issue with fsrw or with your code (could be memory corruption affecting fsrw).I see what you are saying about some of the methods being included in the others however I still flush and close the file before unmouting.
