Power Of The Prop
NWCCTV
Is the Prop powerful enough to both pull in and display live video? In other words, I want to pull live video from an RCA connection in and broadcast it out through either the VGA port or RCA port on a Prop Demo Board. I am thinking no but if it is possible I hope to find out.
No (assuming you want the Propeller to both capture the video and generate an identical (or modified) signal).
If you take a look at the machine vision section of my index (I think it's post #4) you'll see the Propeller is capable of some image capture from NTSC signals.
It is possible to do video overlay. The Propeller Backpack has circuits to do overlay.
