bread board or bus board ?
I've built my audio driver (from another discussion thread) and got it to work an a solderless breadboard. Of course, the problem that the connections are very vulnerable to shaking apart from vibration and handling.
One problem is that the breadboard I received, also has a flaw. One set of edge power bus lines of opposite polarity seem shorted together. Does this happen often. It's a first time for me and took awhile to troubleshoot the problem.
But, that aside, I want to rebuild my circuit to be more vibration and handling resistant.
I'm am gussinng that he easiest solution is to shorten the leads/legs of the "stick up" compontents to just long enough te reach and be flat againt the board.
But, I'm guessing that a better solution is the "soldered PCB prototype busboard." One with pre-connected rows and columns that match the solderless breadboard as close as possible. I am finding a variety of wording in the search keywords that give results. These seem about half the price of the closest matching solderless breadboard. Looking for suggestions on favored suppliers of these.
Plus I want to confirm that circuits built on these are slower in construction. It seems that each componet has to be inserted into the proper holes one by one (using the solderless e breadboard circuit is a reference) Then turning the breadboard over, soldering the lead/legs to the row/column. And finally, clipping the excess ends of the lead/leg off. Repeating for each component. But, of course the benefit of the slower build, is that a mere bump of a component won't cause the circuit to fail.
Are there any other easy possibiliets that I am missing. (no, not talking about an etched PCB.)
Henry
Henry
Al
Al - your idea is intriguing ... do mean hot melt glue?
When I was new to using a breadboard, I occasionally pushed too much wire into the little hole. The wire would curve around and short a connection to the adjacent bus. Could this have been your problem?
I don't think so. I think the metal part of the negative buss in the one corner might be bent and shorting to the adjacent positive bus. If I use the battery wire leads as probes, even just touch the wire tip in one of the batter wire I can see some faint flashes from tiny sparks when I have the lights in the room dimmed. And thing is on first contact from the tip of the wire. Before it's even pushed in. But, some other wire is pushed in too far. So it's worth checking.
An interesting idea. At RS prices of $10 for a breadboard, I wouldn't do it. But the breadboard from the Asain (Hong Kong i think) was only $3.50. Which is about the same price as the PCB soldered one from RS. I admit that I am resistant to making permanent a solder-less breadboard that could be reused for other projects once the circuit has been copied to a soldered on, but I can also see the benefit of not having to rebuild the circuit at all and the hours saved in troubleshooting any mistake.
However, I can also imagine the hot glue oozing down into the holes and somehow acting as an insulator.
Are you talking about using a drop of hot glue where the component lead goes down into the breadboard hole? Hence the above mentioned concern of the hot glue oozing and acting at an insulator.
Or, are you talking about gluing the component itself (such as a resistor, which seem the most common componet) to the surface of the breadboard? Might that hinder heat dissipation? And as there are holes just about everywhere, again might the glue ooze down those hole and cause trouble?
And for the glue gun, are you using high-temp or low-temp hot glue gun? (I know, a low-temp hot glue sounds like contradiction.
Are there glues such that they are a good compromise and hold the compenent down while still able to be removed. Even if with a solvent that is not detrimental to the breadboard itself?
H.
Yes, I think this is what you are talking about.
Matching Printed Circuit Board
http://www.radioshack.com/product/index.jsp?productId=2102846&locale=en_US
RS price of $3.49.
Now this looks much the same solder-less breadboard at RS ($22), that I got from the HongKong supplier for ($3.50).
So I'm guessing that if RS wants $3.50 for the soldered version, then it must be available elsewhere much, much cheaper. (like a $1, or less)
H.
One nice feature of the Proto777 is that the spacing in the middle is a perfect fit for a Basic Stamp or 40-pin DIP Propeller.
Hi, yes a hot melt glue. I do not put the glue into the holes, just on the parts. So if you had 6 parts close together and you glued them together; it would be very hard for the group of parts to come loose. I do this on cheap boards. I do not use this on parts that are going to give off lots of heat, so I don't worry about the glue making the parts warmer.
Al
