Driving an LTC485 - code check?
xanatos
I think I'm doing this all correctly, but the device I'm trying to communicate with isn't responding at all. I'm wondering if anyone sees anything obviously wrong in my code below...
I'm SEROUTing from a BS2sx through an LTC485, which then connects directly to an ICPCON 7017C.
I have the tx & rx enables all set on my code below and I can see data going out...
I have the ICPCON 7017C in "init" mode, which sets it to 9600 baud, address 00. The command string I am sending is actually a string... $002, where the delimiting character is a $, the 00 is the address, and the 2 is a command telling the ICPCON 7017 to read back its configuration data.
I get not a single byte back on the SERIN line.
Code and datasheets below. Note that a few tried-and-failed versions of my SEROUT string are commented out after the last version in there... grasping at straws
' File...... RS485_CommTester.bsx
' Purpose... Development of RS485 network
' Author.... David Xanatos, Xanatronics
' E-mail.... xanatos@xanatos.com
' Started... 09-22-2013
' Updated... 09-22-2013
' {$STAMP BS2sx}
' {$PBASIC 2.5}
' -----[ Constants ]-------------------------------------------------------
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T2400 CON 396
T9600 CON 84
T19K2 CON 32
#CASE BS2SX, BS2P
T2400 CON 1021
T9600 CON 240
T19K2 CON 110
#CASE BS2PX
T1200 CON 3313
T2400 CON 1646
T4800 CON 813
T9600 CON 396
T19K2 CON 188
T38K4 CON 84
#ENDSELECT
' -----[ I/O Definitions ]-------------------------------------------------
Spin PIN 0 ' Spinneret SIO
TXin PIN 1 ' Transmit Data out to LTC485.4
RXout PIN 2 ' Receive Data in from LTC485.1
TXen PIN 3 ' High to tx
RXen PIN 4 ' Low to rx
' -----[ Variables ]-------------------------------------------------------
serStr VAR Byte(11)
' -----[ Initialization ]--------------------------------------------------
OUTPUT Spin
OUTPUT TXin
INPUT RXout
OUTPUT TXen
OUTPUT RXen
Spin = 0
' -----[ Program Code ]----------------------------------------------------
Main:
DO
'DEBUGIN cmdStr
LOW RXen 'HIGH = disable rx; LOW = enable rx
HIGH TXen 'HIGH = enable tx; LOW = disable tx
DEBUG "Sending....", CR
SEROUT TXin, T9600, [$24, $0, $0, $2, $0D] '["$012"] '[$24, $00, $2, $0D]
LOW TXen 'HIGH = enable tx; LOW = disable tx
DEBUG "Receiving....", CR
SERIN RXout, T9600, [STR serStr\11]
PAUSE 2000
'SERIN Ctx, T9600, [WAIT("10"), SKIP 28, STR serStr\11, SKIP 26, STR serStr2\2]
DEBUG "Output = ", STR serStr, " ", CR
LOOP
STOP
Just from my own experience with building RS485 from scratch, I suggest you consider first using an RS232 to RS485 converter with something like Terraterm on a PC to verify your wiring is right.
Then swap to the BS2sx.
You just might be thinking the software is failing you and presumed the wiring is AOKAY.
Nothing is worse than spending a lot of time trying to sort out software code only to find that the hardware was the problem that needed to be sorted first.
Once burned, twice shy.
I now follow careful stepped procedures that include loop back tests to catch problems in wiring.
Of course, you might be more skilled or just luckier than I am. When I skip all this, it generally doesn't work.
More importantly, though, $012<CR> is not [$24, $0, $0, $2, $0D] (or even [$24, $0, $1, $2, $0D]), but simply ["$012", $0D]. IOW, the device expects the commands to be in ASCII, not binary. (See page 62 of the datasheet.)
Pursuant to Loopy's suggestion: it might work, or it might not. Many control devices have very short timeouts for their commands. Trying to type a command from a terminal program may be too slow. This has burned me more than once. IOW, I would stick with the way you're doing it.
Finally -- especially if you're driving a long cable -- use termination resistors (120-ohm) across the RS485 leads at both ends. (To save power, you can put the resistors in series with 0.01uF caps.)
Phil, I just tried the SEROUT as here:
SEROUT TXin, T9600, ["$002", $0D]
Still nothing. I have also tried with and without the resistor, no change. I've even tried swapping the two 485 A and B wires to no avail.
Also, re: enable lines, I originally did have them tied, but in trying various things, I got to wondering if there might be something wrong about that, so i took direct control of them, just in case. That also changed nothing.
I'm certain it's something I'm doing because both units respond identically. Dead silence.....
Open to any other ideas.......
Do you have an oscilloscope that you can use to verify the RS485 output?
You have a very complicated-looking setup there. Why not test first with it stripped to its absolute bare essentials of BASIC Stamp, LTC485, and ICP device, with their needed power supplies -- and with a minimum of wiring jumps?
That's it. The PDB has a lot of other stuff on it, but unless you wire them in, they're not actually connected to anything. Are you saying I should try wiring it up on another board that is NOT the PDB?
I do have a common ground between the stamp, ltc and ICP device.
Also, I only have a crappy little DS Nano for a scope... but that should change soon. I'm monitoring the outputs with LEDs to check for data, but I disconnect them once I see that data is present, and try the link proper.
The ICP 7017c is in INIT mode, which is accomplished by a switch on the back of the device. When in INIT mode, it forces communications to be 9600 baud, 8N1, at address 00, with NO checksum, and using the DCON protocol. Sending that $002 *should* get a response string of several bytes. I don't even get one.
The test program I'm using is posted up in the first post, but I've edited it slightly to try a few things (and to reflect that the RXen is now hard-wired low):
' ========================================================================= ' ' File...... RS485_CommTester.bsx ' Purpose... Development of RS485 network ' Author.... David Xanatos, Xanatronics ' E-mail.... xanatos@xanatos.com ' Started... 09-22-2013 ' Updated... 09-22-2013 ' ' {$STAMP BS2sx} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[ Constants ]------------------------------------------------------- #SELECT $STAMP #CASE BS2, BS2E, BS2PE T2400 CON 396 T9600 CON 84 T19K2 CON 32 #CASE BS2SX, BS2P T2400 CON 1021 T9600 CON 240 T19K2 CON 110 #CASE BS2PX T1200 CON 3313 T2400 CON 1646 T4800 CON 813 T9600 CON 396 T19K2 CON 188 T38K4 CON 84 #ENDSELECT ' -----[ I/O Definitions ]------------------------------------------------- TXin PIN 1 ' Transmit Data out to LTC485.4 RXout PIN 2 ' Receive Data in from LTC485.1 TXen PIN 3 ' High to tx ' -----[ Variables ]------------------------------------------------------- serStr VAR Byte(11) ' -----[ Initialization ]-------------------------------------------------- OUTPUT TXin INPUT RXout OUTPUT TXen ' -----[ Program Code ]---------------------------------------------------- Main: DO HIGH TXen 'HIGH = enable tx; LOW = disable tx DEBUG "Sending....", CR SEROUT TXin, T9600, ["$012", $0D] LOW TXen 'HIGH = enable tx; LOW = disable tx DEBUG "Receiving....", CR SERIN RXout, T9600, [STR serStr\11] PAUSE 2000 DEBUG "Output = ", STR serStr, " ", CR LOOP STOP-Phil
Is this code waiting indefinitely for a reply? If so does this specify how many bytes to wait for?
Once that's done, you'll know that the issue is only talking/listening to the ICPCON.
Cheers,
Phil... yes, the DEBUG line was probably contributing... but I failed completely to see I had a 100ms PAUSE in there as well.
This is why, no matter how good you are, a second set of eyes is enormously helpful.
Thank you all.... everything is working now. Going to go hang my head in shame...
