DAC and two channels
I apologize if this question is terribly basic--I do not even know enough to be dangerous, yet.
I am trying to measure the resonant frequency of guitar pickups. What I was hoping to do with the Propscope is to use the function generator output, then have an x-y plot of the signal before and after the pickup. It appears that I can use either channel 2 OR the function generator, but not both. Is there any way that I can generate a signal with the function generator, and use both channels 1 and 2? Thank you for any suggestions.
I'm not sure about using the DAC and both channels since I don't have a Propscope, but there are other ways to measure the resonant frequency by simply oscillating the coil and measuring the frequency directly. The attached circuit will cause the pickup coil to oscillate at it's resonant frequency. From there you can use the scope to directly measure the frequency.
