About Eddie Control Board with Kinect — Parallax Forums
John ,LinJohn ,Lin Posts: 7
edited 2013-09-16 10:51 in Robotics
I have used “Propeller Tool V1.3.2” to edit my spin code and I already obtained IR ,Sonar, Encoder, Compass data and control Servo motor.
However, I know Kinect’s Skeleton data which only transmits to a PC via USB to give Eddie control Board command. (figure 1)
If I modify this spin code (Eddie.spin), can I obtain Kinect’s Skeleton data on Propeller Tool V1.3.2 ? (figure 2) For example , is this possible with GPIO blocks?
  • Jessica UelmenJessica Uelmen Posts: 490
    Skeleton data from the Kinect can unfortunately only be obtained through RDS4. The Propeller microcontroller simply does not have enough processing power to be able to handle the information coming from the Kinect. This is the reason for the PC-microcontroller hybrid.
