Using a DAT block to provide a sequence of commands and values
Hi,
Ive been having a look if this is possible, and thought i'd ask the experts out there, before i pour countless hours into why it wouldnt work. Basically, id like to have a DAT block, that i could use to feed a series of instructions and values.
Think of it like a CNC program, where I can state:-
move to position 1, wait 100ms, perform this action, wait 200ms.. and so on.
Heres my principle:-
The aim would be POSITION 2, WAIT for 100ms, then POSITION 1. When 255 is read, then thats the end of the line. Could I use something different for end of line, as the values i need to use will be between 0 and 5000 as thats the longest time in millisecs i would want to wait for. Maybe a character?
then calling:-
Is it possible, or am i barking up the totally wrong tree?
It would be nice to have a command sequence more like CNC, ie p002, w100,p001 etc..
Help and advice welcome ! thanks again.:)
'P = POSITION'W = WAIT G1 WORD "P",2,"W",100,"P",1,255
then calling:-
PUB pattern_sequence | Step, Command, Value
Repeat until Step := 255
Step := 0
Command := word[G1][Step]
Step++
Value := word[G1][Step]
Step++
case Command
POSITION : pos(Value) ' POSITION SUBROUTINE
WAIT : wait(Value) ' WAIT TIME SUBROUTINE
CON endCmd = $FF << 24 posCmd = "P" << 24 waitCmd = "W" << 24 DAT G1 long posCmd+2, waitCmd+100, posCmd+1, endCmd PUB pattern_sequence(table) | entry, command, value entry := 0 ' start at the beginning of the table repeat command := long[table][entry++] ' get the table entry value := command & $FFFFFF ' extract the value portion case command & $FF000000 ' execute the command endCmd: return posCmd: position(value) waitCmd: wait(value)You'd call this with "pattern_sequence(@G1)". Depending on the parameter values you want to pass, you could store these commands in words with different amount of bits for the command and value, like 3 bits for the command and 13 bits for the value.Would you mind explaining the :-
Using posCmd, instead of "P" would not be an issue, and aid future debugging.
The aim is, in future, to be able to use a serial transmitted string of command sequences, from a pc to the prop, the prop to store these in data blocks by writing them into memory, then on reboot, recall and execute them. ( more on this later):)
It may have been done ( more than likely) and its a multi stage project.
This I consider to be the foundation
Note that these command sequences can be very complicated. For example, you could have a repeat command that repeats the following command (or commands) a specified number of times, possibly varying the parameter used in the next command as it repeats. You could have test commands that check for some condition and skip the next command if false. You could also have a relative jump command that would jump backwards or forwards a specified number of steps. That's enough to be able to write programs in your CNC-like control language.
If all your commands require a single parameter then you could use letters for commands followed by numbers for the parameter and finish of the list with Z 0 or something unique.
I'm not that familiar with spin but Step gets set to zero at the beginning of the loop so only the first two words will be retrieved.
Sandy
dat ' Format of command string: ' ** "P" { position } ' -- device # ' -- low byte of position ' -- high byte of position ' ' ** "W" { wait } ' -- low byte of delay (milliseconds) ' -- high byte of delay ' ' ** "X" { eXit command sequence } CmdTest1 byte "P", 1, 600 & $FF, 600 >> 8 byte "P", 2, 2400 & $FF, 2400 >> 8 byte "W", 1000 & $FF, 1000 >> 8 byte "P", 1, 2400 & $FF, 2400 >> 8 byte "W", 1500 & $FF, 1500 >> 8 byte "X"I've attached a demo program that reads and displays a command sequence (and holds when a Wait is specified).
CmdTest2 word "P" | (1 << 8), 600 word "P" | (2 << 8), 2400 word "W", 1000 word "P" | (1 << 8), 2400 word "W", 1500pub run_command_demo2(p_src) | ofs, work, cmd, id, value '' Extract commands from DAT string at p_src '' -- uses word format ofs := 0 ' offset into data repeat work := word[p_src][ofs++] ' get command & id cmd := work.byte[0] ' extract id := work.byte[1] case cmd "p", "P": value := word[p_src][ofs++] ' get position term.str(string("Position: #")) term.dec(id) term.str(string(", ")) term.dec(value) term.tx(CR) "w", "W": value := word[p_src][ofs++] ' get wait time term.str(string("Wait: ")) term.dec(value) term.str(string("ms", CR, CR)) pause(value) other: ' "X" or bad cmd value returnIll see where I end up
