Spinneret as a FTP Server
I was cleaning the office the other day and found my spinneret in a box of stuff. I am thinking I want to play with it again. Is there any objects in the obex for turning the spinneret into a small FTP server. I have been searching for a while and have not found much.
I am not sure what the size limitations are for the SD card, I am hoping to use an 8 GB SD card.
Shawn
Shawn
http://www.wiznet.co.kr/sub_modules/en/technical/FAQ_view.asp?PK_NUM=15115&boardcd=102
...written in 'C' for an AVR. I think the Spinneret could easily handle FTP, but it's non-trivial to
implement. Don't recall many complaints about not having FTP, guess it's kind of over the hill.
I'm using a Sandisk 8GB with Mike's code, seems to work fine.
Shawn
I did some stuff using it as an ftp client. I will tidy it up and post it here for reference. It'll be a couple days before I get a chance to do so. Maybe it'll help spark some ideas.
Shawn
Never tried it, so not sure.
This is quite interesting, as there is the documentation of what to do with the server in html files that are located on the server. I will bring up a server soon (currently fighting with my firewall) and the service from serverbeer will be available again. ;-)
The same observations goes for many other threads as well where a lot of effort goes in for very little or disappointing results. Oh, the humanity!
You should really ask this on the Tachyon thread or start a new one.
see answer here
