Single cm gps on Kickstarter
Wow, how did we (meaning all of you + myself) miss this one?
http://www.kickstarter.com/projects/swiftnav/piksi-the-rtk-gps-receiver?ref=live
Do you believe the claims?
True 1cm accuracy can only be achieved by using a reference base at a KNOWN location.
The best they can achieve with that kit is '1cm in relation to the reference'.
And that assumes that they get their SW right.
The kits they're foisting on the backers are 'pre-release' kits that doesn't yet have all the SW.
Ok, I'm no expert, but this seems like it might make sense. Any expert comment?
So, it this something like getting the position of a cell tower for reference? Those are known, and don't move often. If it relies on cell towers, it would then of course depend on the phone system being up and running. So the government could disable it if there was a need.
I don't know. Conventional wisdom says this can't be done. But conventional wisdom is a quick to remind us that every problem gets solves eventually, particularly if it is impossible.
From the Timble site:
http://www.trimble.com/gps_tutorial/dgps-how.aspx
The video claims 4 cm precision and the text says "centimeter level precision" as the precision is measured in centimeters not meters. I think it's fair for them to say 4cm precision is "centimeter level precision".
I'm unconvinced they can reach their stated goal of reaching this precision. My gut (which is often wrong) tells me they are at least legitimately attempting to do what they say.
I think it's kind of odd how close their name sounds to the new CMUcam5's name Pixy.
$900 is how!
From what I have read, professional Land Surveyors pay over $5000 for the same accuracy, and need to sign some agreement.
I have messed with RF, and in particular, Code Division Multiple Access (CDMA) signalling which is what GPS uses, quite a bit. Yes, as claimed, clever algorithms are required to sync up to the Pseudo Noise codes quickly, but this is just "standard" GPS technology.... nothing new here.
As far as directly measuring the phase of the 1500 MHz carrier burried DEEP within the noise at, say, negative 150 dbm..... well I'm a skeptic here.
So, for the claim of centimeter precision.... I would not even bet a nickel !
Cheers,
Peter (pjv)
The idea of solving the location equations by using the centimeter-level carrier phase instead of the meter-level modulated code phase isn't new - it's been done for at least the past 20 years in surveying. My company sent me to take a 5 day course at Trimble around 1992 for a project they were considering, where Trimble explained all about carrier phase locating, most of which was over my head mathematically, but apparently they were able to make it work.
But way back then, it took hours of post-processing the received GPS signals to be able to get the best final result.
If someone has figured out how to embed that processing onto a little chip, then that would be impressive.
http://www.trimble.com/gps_tutorial/sub_phases.aspx
I changed the thread title (from 1 cm gps...) to reflect this claim;
Fair enough.
Doesn't the term "single centimeters" seem kind of strange?
