pipe commands to propellor on USB from command prompt?
Is it possible to communicate to the program on the propeller while connected to the USB via my command prompt? For example if I wrote a program that blinks a led based on a keyboard input , has anyone ever been able to execute this program via command prompt when the propeller is connected to the computer via USB (comport) .. or is the only way to attach a keyboard and lcd/vga display to the board , or use the terminal window in the simpleide compiler?
Which OS are you wanting to do this from?
You can use any terminal program you like to talk to propeller.
One option since you don't mind using the command line is to use the propeller-load terminal.
For example:
1. Open Documents\SimpleIDE\My Projects\Welcome.side
2. Compile the program by clicking the hammer at the top of the IDE.
3. Open a command window to Open Documents\SimpleIDE\My Projects\Welcome
4. Enter this: propeller-load -r -t cmm/Welcome.elf
propeller-load -r -t cmm/Welcome.elf loads the Welcome program from the cmm output folder to propeller ram (-r) and uses the built-in terminal (-t). Press ESC to exit the program.
Once you've done that, add code to read from the serial port using getChar() or other methods.
BTW, just for precise understanding SimpleIDE just calls the propeller-gcc compiler to build programs. All of the steps and results for building programs can be found in the Build Status pane (open with the little green+ hammer in the status bar).
Try either PropForth, pfth, or Tachyon.
Sure, but what do you use on the PC side?
For example, to use propeller-load from python you could do something like:
os.system("/opt/parallax/bin/propeller-load -r -q -t115200 main.elf")What do you mean, on the PC side? If you are running a "terminal" on the PC side in which the "command prompt" appears then there is only the USB to serial connection which is built into a lot of Prop boards or else a USB serial cable. The "very easily" is just that.
BTW, a terminal program such as minicom or TeraTerm etc are more than suitable.
Windows may have pretty much hidden away its scripting ablilites and command prompt. They also migrated away from DOS.
But in Linux, the end user easily can do a heck of a lot with scripts band redirect output to a serial port (or USB serial port), instead of the Standard Output (which is the Terminal Window.
I suspect that you are a Windows user. That might well be the reason that you asked.
