Can't execute function in C based on keyboard input?
I am trying to blink a led on the board which works fine, but I am trying to pass how long I want the pause to be in between each blink based on a keyboard input
I want the pause() function to execute based on what is entered in the keyboard, so for example if I enter "35" , i want the function to be passed as pause(35);
this doesn't work , instead if times out as if there's a non-numeric trailing character in the value or as if it's reading something else
been a long time since I dove back into C , can someone see what's going wrong here?
#include "simpletools.h" // Include simpletools
int main() // main function
while(1)
print("\n enter blink interval:");
scanf("%c", vpause);
print("\n you entered, %c\n");
high(0);
pause(vpause);
low(0);
pause(vpause);
while(1)
high(0);
pause(vpause);
low(0);
pause(vpause);
//#include "simpletools.h" // Include simpletools #include <stdio.h> int main() // main function { while(1) { printf("\n enter blink interval:"); int vpause; scanf("%d", &vpause); printf("\n you entered, %d\n", vpause); //high(0); //pause(vpause); //low(0); //pause(vpause); } }Working examples can be found in the simpletext test program - also in the SimpleIDE package. https://code.google.com/p/propsideworkspace/source/browse/Learn/Simple Libraries/Text Devices/libsimpletext/libsimpletext.c
Can simpletools be bundled with the other libraries already available in the plain GCC release?
If that's what Parallax wants. I'll ping Jeff about it.
