Love the spinneret, hate the low number of I/O pins.
The spinneret is a great device, one that I can capture experiments in a stand-a-lone fashion. But I must admit, I got spoiled by the professional board. I can park 6 different experiments on the pro board and just have fun all day. I bought a spinneret, to make experiments portable. You know, plug in a wireless link to the internet socket, send the data back to my PC through my routers wireless port so I could run experiments in my lab all day and check on them during lunch time. With the limited number of ports for MY i/o, i'm going to need a butt load of spinnerets to cover the number of inputs i need. Is there going to be a spinneret-2 that helps with this problem??
Pretty please???
Pretty please???
In your shift register example, what did you have in mind?
There are plenty of examples in the forum of how to use the 74HC595 and 74HC165 for I/O expansion.
http://www.parallax.com/product/40002
To Paul's point: the Wiznet does look better
To Phil's latest point: If I am measuring pulse widths how does that work with a 74HC595?
How many different pulse channels do you have to monitor?
If you have 4 extra pins and simply wish to webenize experiments, the WIZ820io is a solid choice.
WizNet has a new toy, the WIZ550io. The WIZ550io has an embedded MAC and handles DHCP on start up. The W5500 chip, see thread, has double the buffers, 32k. Plus the buffer are general use. The Prop can store run-time data. So all those little data elements you'd like to persist without using HUB resources is available ove the SPI bus... Cool
