Do I need to invest in an ultrasonic cleaner?
I own a small repair business and I regularly come across dirty PCBs from consumer electronics devices. I am just launching into this and don't really know what I'm doing. One project I'm working on right now is a small PCB that does not power on the device. It has components on both sides (components meaning, ICs, diodes, thermoplastic soldered parts, etc). My goal is to try to get it to power on again. After the PCB cleaning I intend to reflow it, but I'm not completely sure how to do that right either.
I attempted cleaning this PCB by submerging it in a solution of 99.9% isopropyl alcohol and gently wiping it on both sides with a Q tip. I let it dry for a day, then came back to it, and I noticed that it had white crusty corrosion and was still dirty in other places as well. It has what looks like a yellowish tarnish color in places, and now the board is also warped a little bit. Did the IPA cause this warping? By warping, I mean that the board is bending upwards in the middle, in a concave manner.
I'm wondering if it would make sense for me to invest the required $200-$400 in an ultrasonic cleaner at this point. Would the ultrasonic cleaner get rid of the crusty white corrosion, yellow tarnish, and other problems? Would my PCB come out completely clean? Is there any danger of an ultrasonic cleaner doing damage to my PCB? Ultimately, as I said above, my goal is to get this PCB to power on again. What do you guys think? I'd especially appreciate the advice of someone who is in the business of cleaning PCBs professionally. Thanks.
If you're fixing boards with BGAs (xbox, laptops, etc) on them be prepared to completely remove and reflow using a solder stencil or most of your repairs will be temporary.
Most canned PCB cleaner use IPA as a solvent. We used to use a freon based solvent back in the 80's that has been banned.
Immersing in alcohol should not produce any warping unless heat was applied afterwards.
To clean a board, use a brush, a 1" or 2" chip brush with the bristles cut down to 1" to scrub, not lightly. Immerse or cover the board in clean alcohol. Wash the board in water if components will take it. Dry in oven at 125 degrees for an hour.
Works for me.
If you invested in a ultrasonic cleaner, you would still need a solvent. Isopropyl Alcohol is still the best.
Who can spell 'fuel air explosion'?
Or just airborne carcinogens.
I've never used mine to clean PCBs, only car parts so far...
(Industrial unit, HBM 'GL Series' 2.5L, 50W, all around stainless steel)
15 minutes with clean water at 45degree Celsius water stripped the paint off of the brackets holding the gasoline injectors to the HP reservoir...
I have no idea what the silly little 'jewelry cleaner' models can do, though.
OK. Use a venting hood to the outside. We always did that. Should have included that little bit of info.
Personally, I like to use the dishwasher followed by a thorough rinse in distilled water. Dry for several days and/or bake at 150F. Items with lots of nooks and crannies will benefit from a blowing off with low pressure air before drying.
What exactly is in this PCB cleaner you use? I'm guessing it's just a blend of slightly better solvents. IPA is not really all that good as far as solvents go.
The stuff I use is called Misty, it is the safest for plastics. I replacing traditional electrolytic caps with the plastic plug in the bottom so that matters to me. There is another brand that is not safe for plastics but worked better on burnt flux, I got it at Frys but can't find it on their site now.
Using an ultrasonic cleaner for PCBs is a valid solution, but not preferred for many reasons. If you do choose to use an ultrasonic cleaner, you can use a solution of IPA and deionized water (distilled water can be substituted at home) in a 50/50 mix. However, the proper method would be to use an appropriate cleaning agent from Zestron or the like. At work, we have systems made by Aqueous Technologies (not ultrasonic, FYI) and we use either straight de-ionized (DI) water or a DI water/solvent solution. We use solvents from Zestron.
Canned cleaning agents are still available and still used very often. In my opinion, the best products in this category are those from MicroCare. Plus, they are usually easy to source.
Another cause of the residue turning white is inadequate temperature of the cleaning solution. The solution in an ultrasonic system should be above 135F for proper performance. Our wash systems at work vary from 140-160 depending on the profiles and depending on if we are using pure DI water or DI water with an added saponifier that is designed to break down our types of no-clean fluxes.
Here are a few more links for additional information:
http://www.ipcoutlook.org/mart/50350D.shtml
http://www.circuitnet.com/experts/73284.shtml
http://www.circuitnet.com/experts/68860.shtml
P.S. Been in the PCB manufacturing industry for 22 years and have been personally responsible for 6 different wash systems. The latest craze is cleaning no-clean PCBs. The trick is remembering that there is no such they as a no-clean flux. Only no-clean processes. Many of the products we wash at work were manufactured with a "no-clean" paste or wave flux, but even though the flux residue is acceptable if left on the board, we remove it based upon customer, cosmetic, or conformal coating requirements.
I've heard that one should not use an ultrasonic cleaning procedure on boards that carry a tuning fork crystal, i.e. a 32kHz. Is that really a concern in your experience? That is an explicit warning in the data sheet for the real time clock chip that I use, one with embedded crystal (ISL12020MIRZ). I'd think that would be a problem only if the cleaner operating frequency is near the crystal resonant frequency. I've also heard that automotive and jewelry cleaning systems use a much lower frequency (~40kHz) than electronic systems, which may be above 100 kHz.
ps. another example of how assuming the datasheet gives you everything you need to know is a bad habit.......
If you are cleaning PCBs then you need Chem-Wipes or something similar to soak up all the dissolved flux or it will just redeposit on the board as white powder. Older solder was Rosin Core but newer solders have No Clean flux. Rosin flux takes some effort to remove.
You need to be careful though because some items like switches and piezos can be messed up if you get flux residue inside them.
