Propeller Activity Board: The Current Shortage — Parallax Forums
Jessica UelmenJessica Uelmen Posts: 490
edited 2013-10-18 09:47 in Propeller 1
Wanted to pop in quickly and give you a quick update on the status of the Activity Board. The out of stock question had been asked about previously, and while initially we were out of inventory, things have changed a bit since then. Unfortunately, the worst has happened and we've uncovered a slight design issue.
Specifically, we've seen intermittent noise in the power supply on some boards, which causes XBee modules to not operate correctly when connected to the XBee header. The solution lies in a capacitor part change, which we are in the process of implementing.
However, this issue isn't present on all boards. Boards in the initial shipment are fully functional, and a only portion of the more recent shipments (after 5/17/13) are affected.
I've attached a test to this post which allows you to test whether your board is exhibiting these symptoms (please be sure to follow the directions at the top). If it is, please contact sales@parallax.com for a hassle-free replacement. Distributors, you'll be contacted by your sales rep directly for replacement information.
Any questions, comments, or concerns? Please post 'em here. We want to make this right for people as quickly as possible so that you can get back to creating! And of course, we're very sorry for any inconvenience this causes.
  • propMakerpropMaker Posts: 65
    edited 2013-08-27 19:28
    I ordered my board from Propeller Powered. I don't have to do the test to know I will probably have some noise. The capacitor on the board is lifted up and being held on by the tip of one lead. It looks like the solder didn't bond to the capacitor leads at all. I tried to get a picture, but I cant get any of my cameras to focus that close. I wasn't really concerned. I planned on re-soldering the capacitor, I've just been too busy bother with it.
  • SRLMSRLM Posts: 5,045
    edited 2013-08-27 22:20
    propMaker wrote: »
    Sounds like the capacitor has tombstoned. A picture would be interesting.
    edited 2013-08-28 04:22
    Hi Jessica,
    I tried your test on my Activity Board and both LEDs remained lit. I guess I got one of the good ones!
    David
    edited 2013-08-28 05:08
    I ordered my board on 5/24/13 - both LEDs stay lit when running the test so I guess I got one of the good ones too!
    edited 2013-08-28 05:45
    SRLM wrote: »
    My camera with the good macro function hasnt been used in a long time, the focus mechanism appears to be siezed up. I could try taking a picture at work through the microscope. There is an indentation in the solder where the lead was setting. If other boards are doing the same thing, but the capacitor doesn't get knocked off, then it would be hard to find the problem visually.
  • Hal AlbachHal Albach Posts: 747
    edited 2013-08-28 07:45
    Any idea when the board will become available for new orders?
  • Jessica UelmenJessica Uelmen Posts: 490
    edited 2013-08-28 08:31
    Glad to hear we've got good boards out there! :)
    propMaker,
    PM me your shipping address and I'll get a good board to you ASAP. No need to go back through Propeller Powered.
    Hal Albach,
    We're hoping to get boards back in stock within the next couple weeks. We have many boards on backorder, so we'll be filling those orders before you'll see stock on the website.
    edited 2013-08-28 10:32
    Thank you Jessica for making issues streamlined and easy!
    I'll watch for the "reseller annoucement" regarding how we should handle this.
    Thanks!
    Jeff
    edited 2013-08-28 15:49
    Not the best quality pictures, smart phone through microscope eyepiece.
    1024 x 1712 - 150K
    1024 x 1712 - 150K
  • David CarrierDavid Carrier Posts: 294
    edited 2013-08-28 17:46
    propMaker,
    It looks like your board was damaged in transit, since the solder in the he pad for the capacitor has a hole matching the shape of the lead. The electrolytic capacitor is big enough to give a lot of leverage, so external force can pry it off the board. Normally the lead would lift the pad with it too, but in this case it is connected to a ground plane through several wide traces that hold the pad firmly in place. The test Jessica posted only tests the 3.3-volt supply, which is the one that the XBee modules use. Without the electrolytic capacitor you pictured, your 5-volt supply may be noisy or react poorly to changes in current, but the 3.3-volt supply may still work fine.
    If a board has a noisy 3.3-volt supply, you won't be able to see anything physically different, because it is due to an interaction between the voltage regulators, but if you haven't damaged your ears from listening to loud rock music, you may be able to hear the problem. Most types of ceramic capacitors are mildly piezoelectric, so they vibrate as the voltage changes. If the board has electrical noise, the ceramic bypass capacitors will convert it to audio noise, and if you have a sensitive ear, you will hear an 11,000 to 15,000 Hz whine.
    — David Carrier
    Parallax Inc.
    edited 2013-08-28 19:08
    I'm getting both LEDs, most of the time. And my dog like ears aren't picking up migraine inducing noise.
  • jazzedjazzed Posts: 11,803
    edited 2013-08-28 20:08
    I have one good old board, and one bad new board. Sent email to sales.
    edited 2013-08-28 20:11
    In response to transit damage, we've had a devil of a time making sure these arrive in good shape.
    (Note: Parallax has ALWAYS helped us with any that arrived here with any noticable damage!)
    I've started packing them in multiple layer of bubble pack from Propellerpowered in the attempt to make sure they arrive to our customers in good shape.
    @propMaker: was your well packaged when it arrived? Thanks for the pics, I'll add cap inspection to my inspection list here.
    Jeff
    edited 2013-08-28 20:15
    The electrolytic capacitor is big enough to give a lot of leverage, ...
    Hot-melt gllue might solve that.
    edited 2013-08-28 20:40
    two good boards here.
    edited 2013-08-28 20:42
    Jeff
    It was packed very well. I didn't see any damage to the outside of the package either.
    edited 2013-08-29 09:40
    @PropMaker,
    PMing you.
    Jeff
    edited 2013-10-05 19:42
    As it turns out, the board that I received from Adafruit early in September has failed the test, only P27 lights up. My DVM shows the 3.3 volts to be at 3.18, not sure if that's the issue, but either way, P26 stays dark. And when I try to use the ADC to measure the 3.3 volts per the tutorial, the readings never settle down, at times varying by as much as +/- 0.3 on the float. I have sent an email to both Adafruit and Parallax, I just hope it will be resolved.
    Hal
    Had time this morning to look at the Activity Board with a scope and found some interesting items. Notably, the board nearly always passes the test when powered by the USB port. When I power the board from a 7.2 volt battery or wall wart then the board ALWAYS fails the test. When powered with the battery the +5 rail has an 800 mili-Volt P-P AC pulse riding on the +5 at a 20KHz rate. The 3.3 Volt rail has a 400 milli-Volt sawtooth waveform at the same 20KHz rate. On the scope Vin is clean and steady at 7.2 Volts.
    When USB powered, both rails are clean.
    I placed a 100uf Cap from +5 rail to ground in the proto area and nothing changed
    I placed a 10uF Cap from the 3.3 rail to ground in the proto area and all the pulses and sawtooths disappeared, and the board passes the test every time with the 7.2 Volt battery as the power source. The ADC reading the 3.3 rail fluctuates +/- 2 milli-Volts.
    Wonder if anyone else with a failing board has the same result?
    Here are the scope images...
    +5 rail............... 3.3 rail
    Scope settings: 20us/div, 200mV/div, AC coupling
    Hal
    1024 x 1365 - 143K
    1024 x 1365 - 122K
    Just an update; On the 10th I notified Sales Support that I had a defective Activity board, received a reply the next day that a replacement will be sent. It arrived this morning via priority mail along with postage to return the old unit. Tested the board using USB power and battery only power and both leds lit up every time. A quick glance over the two boards yielded no discernible difference. Gotta love Parallax, they really care about their customers.
    Hal
