Catalina 3.11 - now 100% open source! — Parallax Forums
RossHRossH Posts: 5,737
edited 2013-10-09 01:18 in Propeller 1
I've just posted a new release of Catalina (3.11) to SourceForge. I've posted the usual Windows "one touch" installer (here). Linux 32 bit and 64 bit versions are also available (here). See also any "errata" that appear in the following post. This release makes Catalina 100% open source.
Catalina also now supports OS X, but there is no binary distribution - it has to be build from source (use either of the Linux distributions).
Catalina also includes BlackCat and BlackBox source-level debuggers (note BlackCat is not open source) the Code::Blocks graphical IDE, and the Payload program loader - which can now load any program, whether to Hub RAM, EEPROM, SRAM or FLASH.
Here is a brief list of the main improvements in this release. For a full list, see the README.WhatsNew file or the Catalina Reference Manual.
  • By default, Catalina now uses the openspin spin/pasm compiler to assemble the PASM code generated by the compiler. Full sources for this compiler are included, and it is MIT licensed. The openspin compiler has been modified to support some Homespun features needed by Catalina. The openspin compiler has been tested with all Catalina sources, but Homespun is still provided in case any problems are discovered.
  • There is a new SD card plugin, which supports SDHC cards (i.e. SD cards over 2Gb in size). This new plugin is used by default. The old plugin is still provided in case any problems are discovered.
  • Catalina now supports PASM instructions inline with C code. For instance:
void main() {
    PASM ("mov R0, #1");
    PASM ("mov outa, R1");
  • Added support for the RamPage 2 board, via the command line symbol RP2. See the file RP2_README.txt in the Catalina target directory for more details.
  • Catalyst is now entirely a C program - this has been made possible by Catalina's COMPACT (CMM) mode, which means C programs use only about the same amount of memory as Spin programs. All the Catalyst utilities (mkdir, rmdir, cp, ls, cat, rm etc) are also C programs. In some cases, the C versions of the utilities have additional options. Catalyst supports all platforms supported by Catalina, suports SDHC cards, and supports loading programs from SD Card into Hub RAM. or XMM FLASH or SRAM. On multi-CPU propeller systems (e.g. TriBladeProp, Morpheus) it also supports loading programs into other CPUs. The main advantage of converting Catalyst to C is that Catalina and Catalyst both now only use DOSFS for all file system access - no need to mess with any others any more.
  • Included binaries for the LMM/XMM version of the Catalina Optimizer (the CMM version was already included). The source code will be released once I have had time to tidy it up.
  • Quite a few minor bug fixes!
There is one known bug in this release, but I have had so many requests for various things that I had bundled into this release that I have decided to release it anyway. The bug is that on one platform (the TriBladeProp), some instances of SD cards (but none of the SDHC cards I have tried!) simply will not work. Not sure what this is about yet - but if you strike this problem, you can always revert to using the previous SD card plugin - you can simply select it on the command line via the symbol OLD_SD:
catalina program.c -lc -C OLD_SD
One reason I have decided to release it with this bug unresolved is that I half suspect it is due to some peculiarity of my TriBladeProp, and I'd like to see if anyone else has a problem on other platforms, or with other SD cards.
Ross.
«134
  • RossHRossH Posts: 5,737
    edited 2013-08-27 07:16
    The attached errata file contains a new version of payload which can dramatically reduce the download time for both Spin and Catalina binaries on some computers. The updated source file (payload.c), and a new binary for Windows, Linux 32-bit and Linux-64 bit systems are all included in the attached file. Unzip this file and then copy the relevant version over your Catalina 3.11 installation. See the included README.TXT for more information.
    Update 1: This version of payload also allows the port names to be explicitly specified on the command line via the -p and -s command line options (this is in additon to being able to specify them by number). For example:
    payload hello_world -p /dev/ttyS0 -s /dev/ttyS1
    You can still specify ports by just specifying a number alone:
    payload hello_world -p 1 -s 2
    This is particularly useful on Mac OS X, where the names of the USB ports are impossible to predict in advance. For example:
    payload hello_world -p /dev/cu.usbserial-A20e1ep0
    Update 2: The errata file now also contains a new version of the blackbox debugger (which fixes a bug to do with displaying structures when passed as parameters to a function) and a new version of the catdbgfilegen utility (used by Catalina to generate debugging information used by both blackcat and blackbox). The new version of catdbgfilegen is much faster at generating debugging information. Also, with this version (which is now written in C++) Catalina no longer requires mono to be installed on non-Windows systems (mono is a set of utilities to allow C# programs to run on other systems).
    Finally, the errata file contains fixes for a number of updated makefiles and batch utilities to enable Catalina to be compiled under OS X (note no binaries for OSX are included - Catalina must be recompiled from source. Instructions on how to do this are included in the Catalina Reference Manual).
    edited 2013-08-27 07:22
    Very nice Ross! But Sound Forge Shows Catalina_3.10_Setup as being the latest. Maybe not migrated yet?
    Jim
    edited 2013-08-27 07:29
    Excellent work Ross!
    I am going to download it and play with it.
    edited 2013-08-27 07:32
    Publison wrote: »
    Jim
    Takes a few minutes to propagate, I think. It is showing it now.
    edited 2013-08-27 07:36
    Sweet! Got it!
  • OldFartRadiomanOldFartRadioman Posts: 30
    edited 2013-08-27 11:33
    Just downloaded and installed on a XP machine. Going through the Code Blocks Quick Start and all is good until Download to Hub Ram and Interact after which I get the error: unable to open file catalina.binary in the cmd window.
  • Hal AlbachHal Albach Posts: 747
    edited 2013-08-27 13:37
    Just ran through the Code::Blocks quickstart and after the build I select Tools>Download Hub Ram and Interact, and it takes a full minute for the text to appear in the Terminal Window, during which the USB receive light is constantly on. I'm using a Propeller Project Board -USB and left the target board setting to Custom. Does Payload normally take that long to download or (more likely) did I miss a step or two in the initial setup?
  • RetrobitsRetrobits Posts: 46
    edited 2013-08-27 14:22
    First of all, hooray! Nice work, Ross.
    Also - Could someone give me a hand adapting the configuration for the new Propeller Memory Card from Parallax? Ross mentioned it might be similar conceptually to the RamPage2 config.
    http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/ProductID/927/List/1/Default.aspx?SortField=UnitCost,ProductName
    I'm willing to get in here and do what I can - but I have a feeling some of it is over my head...
    Thanks!
    - Earl
    edited 2013-08-27 15:23
    Retrobits wrote: »
    Thanks!
    - Earl
    The Propeller Memory Card uses different flash chips than the RamPage2 so you'll need a slightly different driver. Also, the RamPage2 has two flash chips and two SRAM chips to allow 8 bytes to be written/read at the same time. If the Catalina driver supports that it will need to be changed for the Propeller Memory Card since it only has a 4 bit data path to memory. However, Ross tells me that his memory drivers are similar to the ones used by PropGCC and there is a PropGCC driver for the Propeller Memory Card so you might be able to use that.
    edited 2013-08-27 15:46
    Cool Stuff!
    edited 2013-08-27 16:41
    Hi OFR,
    Did you get an error message during the compile? IF so, please post your Code::Blocks build log.
    Also, try doing a complete rebuild of the project (i.e. Build->Rebuild).
    Ross.
    edited 2013-08-27 16:48
    Hal Albach wrote: »
    I have had previous reports of payload running slow on some machines - most likely the cause here is the "auto-detect" function of Payload which has to identify which port you are using. To verify if this is the case, try compiling and loading a file from the command line. Open a Catalina Command Line window (use the shortcut installed to do so) and type something like:
    cd demos
    catalina hello_world.c -lc
    payload hello_world
    Don't worry whether it ouptuts anything - I just want the download time. If this works but takes a long time, note the COM port that payload uses (it will tell you this), then specify this explicitly via the -p parameter. For instance, if payload said was using "COM22:" then try:
    payload hello_world -p22
    Let me know how you go. We can modify your Code::Blocks download command if you always use the same COM port.
    Ross.
    edited 2013-08-27 19:07
    Good Evening, Ross; Tried the command lines per your suggestion, unfortunately, both payload commands also took just over a minute to load. I have two Propeller Project Boards-USB, the older Rev A board uses com5 and the newer Rev B uses com8. I have only tried this on the Rev B since that is the one with the 5MHz crystal.
    edited 2013-08-27 19:17
    Hal Albach wrote: »
    Ok - I will try and think of another way to see what is going on. It definitely should not take a minute to load a program that small. I'm not a USB expert, but could your computer have a USB 1.0 port? All mine are at least USB 2.0. Another possibility is that the load speed is just very USB-chip specific. Any chance you could try using the same binary and propeller board, but from a different PC?
    Ross.
    edited 2013-08-27 19:37
    Thanks Ross :)
    edited 2013-08-27 19:42
    I loaded Catalina on the home machine and it compiled hello_world with no problem but I see the long download times. Tried from the command line and using the -p switch in payload and saw no change.
    edited 2013-08-27 19:55
    Hey Ross,
    I'm glad you were able to use OpenSpin here, one issue though. Your changes a pretty significant and it would probably be best to call the exe openspin-catalina.exe (or something else you prefer) instead of openspin.exe. If people have the current version of OpenSpin from google code installed and catalina installed it's possible they'll get the wrong exe running for catalina or for non-catalina stuff. Maybe in the future as features are added to OpenSpin and you no longer need your customizations then it won't matter.
    I've been looking over the diffs, and I am curious why you did a few of them, like undoing the preprocessor state set by sub objects (seems really broken and undesirable to me), and the changes to the compiling of the @ operator (not even sure why its needed?). As for listing files, I have different and more comprehensive plans for listings, so I won't be bringing your version over.
    Roy
    edited 2013-08-27 20:30
    Hello Ross,
    I did not have another machine but I did switch to a different USB port and the load time dropped to 7-8 seconds. My machine is a custom made gaming system with supposedly the latest in hardware, I-7 8 core cpu, SSD, etc., so I don't think I have any USB-1 ports. However, the port I was using was blue, while all the other ports are white or black. using either white or black gave me the reduced load time. Does the 7 second load fall in line with what you are expecting?
    Hal
    edited 2013-08-27 20:48
    Hal Albach wrote: »
    Hello Ross,
    Hal
    Yes! Thanks.
    If you can find any specs that might tell us the difference between the ports, it would help others who are also apparently seeing the "slow download" problem. I could never reproduce this problem on any of my machines!
    Ross.
    edited 2013-08-27 20:49
    Can you try another USB port? See post above!
    Ross.
    edited 2013-08-27 20:53
    The blue ports are USB 3 ports, but those should be USB 2 backward compatible.
    Roy Eltham wrote: »
    Hey Ross,
    Roy
    Hey no fair! - I actually had openspin before you guys did! But I'll change it next release - the name of the executable doesn't matter to me.
    As to why some of the changes exist - it is usually for compatibility with Homespun. Over time I may get a chance to eliminate these differences. Some of them are pretty obscure.
    My listing code is a real hack! I don't expect you to use it, but I needed something. If you come up with better code then I'll adopt it.
    Ross.
    edited 2013-08-27 20:56
    Roy Eltham wrote: »
    How odd! I have a USB 3 port on one of my machines - I've never used it for my Propeller comms. But I just naturally assumed USB 3 would be faster, not slower!
    I'll try it tonight and see if I can see the "slow load" problem.
    Thanks, Roy.
    edited 2013-08-27 21:29
    Yup, that blue one was one of two USB 3 ports. For what its worth, it worked without issue on all sorts of things that I plug in from time to time. My Garmin GPS for map updates, Silabs developement system, MP3 players old & new, and even SimpleIDE. Well, at least now I know when Santa Clause brings me the latest whizbang gizmo needing USB 3 I am fully ready for it.
    edited 2013-08-27 21:34
    I may implement those changes with a command line switch to enable them then. A "Homespun" compatibility mode, maybe? I assume the proprocess state in sub objects one is Homespun, is the change to the @ operator code for that too?
    When you say you needed something for listing files, do you mean catalina is using them for something or you just needed to see the output structured in some way? If you just need to view a binary file disassembled or as a listing file like view, I use PropList. Inside the PATCH.ZIP file in this message: http://forums.parallax.com/showthread.php/96211-Spin-Bytecode-Disassembler?p=744399&viewfull=1#post744399 You may already have that, just sharing in case you don't.
    USB 3 is much faster than USB 2, but it requires a different cable/connector. They made the plug capable of accepting a USB 2 connector and work as USB 2 in that case. It's probably an issue with the ftdi drivers.
    edited 2013-08-28 00:14
    Roy Eltham wrote: »
    Yes - as is the FIT statement allowing up to $1FF (instead of $1F0). I think the @ operator change may actually be a bug in the original Spin compiler - I could certainly not understand why it was limited the way it was.
    Roy Eltham wrote: »
    BlackBox, BlackCat and the Optimizer all parse the listing file to get symbol information. so it was easiest for me to just hack something up that generated the appropriate listing format. I was unaware of PropList - but if it doesn't show actual symbols it won't be much use. I can wait till you implement your "proper" listing format and then adapt all the consumer programs to expect that format instead.
    Roy Eltham wrote: »
    It certainly sounds like a USB 3 issue - now that I know what it is, it should be easy to find and fix.
    Ross.
    edited 2013-08-28 01:58
    RossH:
    I looked more carefully at the @ operator change, and I think I agree with you. If I understand correctly, it allows you to use @ on asm local symbols (e.g. @:symbol). I think I'll just include that as a "fix".
    The $1FF vs $1F0 change is to allow you to compile stuff that would write into the shadow registers at cog load time, right? I think this probably needs to be enabled by an option, because it could cause issues for someone who doesn't understand how that stuff works in detail.
    For the preprocessor, as I understand it in my version parent objects do not "see" #defines from their child objects. The child objects "see" the #defines of their parent and the #defines of other children compiled before them. With your changes, the child objects only "see" the #defines of the parent and *not* the #defines of the child objects compiled before them. My version is more like the way C/C++ preprocessing works, but missing one key part. The parent should "see" the #defines from it's children. That would match how I think it should work, #defines being "global" from the time they are parsed until they are #undef'd or preprocessing ends. Of course, this is treating OBJ stuff like they are #include's which is not really right either. So one could argue that OBJ's should be treated like a separate compile and thus shouldn't see any #defines from it's parent or children. It seems more useful to allow children to see their parent's #defines and parents to see their children's #defines, but children should probably not see their sibling's #defines. That isn't possible without changes to the preprocessor state handling.
    I think I'll just keep mine working as it is now, because I think it works like BSTC does (though I'm not 100% certain of that anymore), and add an option to do it like homespun does.
    Thoughts?
    Roy
    edited 2013-08-28 02:02
    I have always found payload to be extremely slow (>30 seconds). None of my laptops have USB3.0 and they all exhibit the problem. I have the latest FTDI drivers.
    edited 2013-08-28 02:04
    RossH wrote: »
    The advantage here being?
    edited 2013-08-28 02:07
    kuroneko wrote: »
    I can store values in unused "special" registers.
