Programming the Spinneret over the web?
xanatos
Just wondering if there might be any work underway in figuring out how to download programs to the propeller onboard the Spinneret via the network connection? I'm thinking it would probably require that the programs load to a second propeller which would in turn load the Spinneret's propeller, but... it *seems* like it may be do-able. Anyone know differently, or tried such a feat?
Dave
EDIT: Actually, could you load the upper 32k in the Spinneret's eeprom with the new program, then have the propeller copy the upper 32k into the lower 32k and then reboot???
Dave
http://174.97.235.77:5000/advanced/program.htm
Forum Post
http://forums.parallax.com/showthread.php/132562-Program-a-Propeller-with-the-Spinneret
You can also upload a bin file and use the SD driver to load an image. You'll have to be careful of image corruption and plan a rollback path.
http://forums.parallax.com/showthread.php/149819-PUT-MKCOL-DELETE-HEAD-and-OPTIONS-Handler-for-W5100-W5200
This development uses the new driver and libraries. I strongly suggest migrating to the new code base.
Dave
