PMB-648 GPS Module satellite lock?
Purchased one fr Radio Shack. Can I power it at 5V by batteries just to see if I can get a Satellite lock? When connected to my controller (R-pi, modelB), I only get a flashing LED, never a lock. It is positioned with clear view of sky. When conncected to R-pi, I had red to 5V, blk to Gnd, and yelow (Tx) to pin 10 (Rx).
Thanks, Mike. I used a 9vbattery + a voltage regulator (7805), to be sure would deliver enough voltage (in case the pi was not), and still had some trouble getting a satellite lock. BUT, it turns out there was/is some interference from either my pi or my monitor blocking a good satellite lock. With the battery hooked up and disconnected from the pi (i.e., away from the pi), I got a good lock. So, once I moved the GPS 1 meter away from the pi / monitor, I could get a lock with the GPS connected to the pi (5v and Gnd). This all took a bunch of troubleshooting to confirm. Now, using only the yellow (Tx) to the pi's Rx GPIO, everything is working. I will figure out later whether indeed it is the pi or my monitor that is interfering. If it is the pi, that is a little concerning long-range, because this is supposed to be all in a balloon payload eventually. Just FYI, on the pi I I just have a USB keyboard, HDMI/VGA to a screen, and the pi's input power adapter; it is not running anything else (yet).
Anyway, thanks.
/S
