Basic Stamp input High/Low values
Stamp Gurus,
I've looked for, but could not find the Vil/Vih for a Basic Stamp pin set as input.
Anyone know, or know where this could be found?
Thanks much.
Thanks much.
Yes, you do - and I was thinking similar values; looking for "official docs".
"...and don't call me Shirley"
Synapses are firing slowly today...
Yup - I went down that path. Now if the datasheet is correct, then the often stated 1.3-1.4 volt transition range is not.
Have you any empirical experience? I'll be checking this over the weekend in between stripping the kitchen cabinets.
Hi Mr. Allen, thanks for weighing in.
Actually, the data sheet does answer my question as I'm not interested in the exact transition point - even though this thread kinda went in that direction.
I needed to know the "guaranteed" points at which the Stamp (either PIC or SX) would call an input level high or low. And yes, they appear to be the somewhat standard TTL thresholds.
