What controller do I need?
Hi, I have been working with a PLC but I find it very slow programming and processing speed is not the best and I would try with a controller but I have many doubts because I've never used one.
I'm looking for a controller that is able to:
· 2 OUT motor step by step
· 22 or more IN digital
· 2 high Speed IN Digital
· 6 IN analog
· 2 OUT Digital
· Screen
· Timer´s
· Clock in real time
· Memory for Array
· Programming language
And the ability to scale the inputs, outputs and memory
I also need to connect the controller with an electronic compass and a device that tells the caterpillar robot how far and in what direction is the home position.
What would you recommend me?
I would appreciate any help!!!
Best Regards,
Ariel
· 6 IN analog
· 2 OUT Digital
· Screen
· Timer´s
· Memory for Array
Best Regards,
Ariel
If you could add the following to your post you will get a better answer:
- speeds required for the analog and digital inputs
- screen resolution for the display
- size and type (volatile or permanent) of memory for the memory array
- programming language desired
There are many programming languages available including Spin, C, PASM, Forth, and Basic.
I'd suggest starting with a QuickStart board of a Propeller Project board.
