Can someone help me figure the current draw?
Oldbitcollector (Jeff)
I need some help with coming up with the "current draw" of the following items.
64k Eeprom, Propeller, and 3v regulator.
I've got a project idea that would use a Propeller, but my existing 5v supply can not be over 50mA.
Thanks!
Jeff
Thanks!
Jeff
With that 50ma limit, it seems that only 5 cogs running full out at 80mhz is possible.
If you hit a barrier that requires more cogs, slowing down to 40mhz might easily allow all the cogs to work well. But you also need to budget power for whatever the 32 i/o pins might be driving.
