Adventures in Forestry — Parallax Forums
rjo__rjo__ Posts: 2,114
edited 2013-08-14 19:03 in General Discussion
This has nothing to do with Parallax products... but I really don't frequent any other forums and the good folks here
seem to know just about everything... so, here goes:
I was using a Craftsman 18" electric chainsaw, with a two year extended warranty, to remove some dead trees from
our property.
I watched all of the Youtube videos to make sure I knew what I was doing.... and today, I cut down a tree, but
it fell in the wrong direction and kind of hung up on a neighboring tree. It is kind of scary just hanging there like that.
Now what do I do? No fair calling for help... I messed it up, I want to fix it.
Do I need a winch? What do I hook it to? Can I use a hand winch and a bunch of pulleys... never understood pulleys much.
Rich
    edited 2013-08-08 20:04
    Can you post a pic? ... with a similar quote for dealing with HV electricity ..." tree's are something you should respect and can be deadly dangerous if not handled properly" ... there is a lot of potential energy built up in a tree that you don't realize until it comes crashing down where you don't want it.
  • rjo__rjo__ Posts: 2,114
    edited 2013-08-08 20:11
    I had my camera in my car... but I was so dumbstruck, I just stood there looking at it. 3D photos tomorrow. "Potential energy" indeed. At first it was hung up on the stump. Can't tell you how careful I was cutting the final nubbin holding it in place.
    Dead rotten trees... they do what they want:)
    edited 2013-08-08 20:24
    We had a storm come through about a year ago the dropped about 40% of our Silver leaf Maple tree in our front yard. The tree stands about four stories tall.... I ended up cutting about 400 Cubic feet of fire wood out of the event, when a portion of it fell. I was standing at the front doorway of the house during the event.... very scary, and lucky it didn't fall in my direction. funny about two months later we had to have the water line to the house repaired... The ground ripple/shaking from the tree falling and hitting the ground (imagine a rock on a pond) was enough to crack the water line going into the house, but it took about two months for us to visibly see the leak (puddle) form at the yard surface.
    edited 2013-08-08 20:25
    Been there, done that :)
    Lots of solutions with ropes/pulleys etc and a photo will help a lot.
    Safety first. I'd be very scared going even near it till you work out what to do. Plan it in advance and there should be a safe solution.
    Look forward to seeing the photos.
    edited 2013-08-08 21:24
    rjo__ wrote: »
    ...No fair calling for help... ...I want to fix it....
    I've cut down a lot of trees and, to put it mildly, it's dangerous shtuff when they get hung up. You really need to have a sense for how wood might split on you, how the bending moments and shear forces, etc. are "alive" in the tree.
    Anyway, maybe have a look at this just to get some ideas???
    edited 2013-08-08 22:10
    I have cut down a few trees over the years and the general approach I take is to use a rope and pulleys to bend it in the direction I want it to fall. I tie the rope as high as I can in the tree that is to come down, and as low as practical in two trees to either side of where I want it to fall. Once that is done I cut a V notch about half way through the trunk on the side of the tree facing the direction I want it to fall, and then cut from the opposite side of the trunk. So far it has worked pretty well.
    edited 2013-08-09 12:13
    Here's something to cheer you up in the meantime...
    http://www.youtube.com/watch?v=5zey8567bcg
    edited 2013-08-10 17:55
    ROFL... thanks.
    As promised here is the tree in all of its 3D glory.
    Haven't figured out what to do with it yet... but I will get a video when I do.
    768 x 216 - 46K
    edited 2013-08-10 18:06
    Could you just wrap a chain around the trunk and pull it out of the other tree with your truck?
  • Mark MaraMark Mara Posts: 64
    edited 2013-08-10 18:34
    We call what you have a widow maker. Given your experience, the safe thing to do is what Phil suggested. If you can’t pull it free it would be a good idea to hire a tree guy. Don’t start cutting unless you really understand the forces involved.
    Good luck.
    -markM
    edited 2013-08-10 19:01
    I agree with PhiPi and Mark. I had a similar situation only last month. A vehicle is much safer - if the rope/chain snaps you are protected inside the vehicle. Can you get a vehicle to where you took the photo?
    edited 2013-08-10 19:13
    I'm not an expert, so take this comment with a splinter of salt.
    If I were faced with that situation, I would get me a very thick hemp rope to tie between the tree trunk (near where you cut it) and the trailer hitch of a vehicle. I don't suggest using a chain because if the chain breaks, it can whip back toward your vehicle and cut your head off. Chains are a lot stronger than hemp ropes, but when they break or slip, they can fly around and they can have enough stored energy + mass to do some major damage. Secondly, I would first try to pull perpendicularly to the trunk of the tree. In other words, have thy rope making a right angle to the trunk of the tree. Also, make sure the rope is long enough that your vehicle is well clear of the tree, and keep everyone away from the scene in case the rope breaks and whips around.
    EDIT: but try not to use anymore rope than you need - you don't want too much elastic energy stored in the thing in case it slips.
    If you don't have a vehicle, consider a "come-a-long" or winch or something, but whatever you do, do be overly careful.
    EDIT: I would NOT try the technique of rolling the trunk that was shown in the video I posted earlier. Your tree appears too horizontal for that technique to work.
    EDIT: make sure you pull on your rope nice and steady. Don't let the vehicle jerk it.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2013-08-12 21:38
    Easy peezy. Rent a Cherry picker. Start at the portion of the tree that is caught up. Make sure you get a Cherry picker with a long enough boom where the vehicle can not get damaged. Gravity will prevail once you cut the right branches from the tree. ( I grew up as a teen cutting trees with my stepdad. That was his gig, I actually learned a lot more than I ever realized and have cut several trees down over the years.)
    edited 2013-08-13 10:10
    NWCCTV wrote: »
    Rent a Cherry picker. Start at the portion of the tree that is caught up. ...
    Be aware that the branches of the tree now holding the fallen tree are under a lot of stress. Once the fallen tree drops to earth, those stressed-out tree branches might whip upwards. You, your cherry picker, and your teeth might end up getting launched into the sky.
    edited 2013-08-13 15:26
    A couple of ropes positioned correctly will take care of this. Like I said, I did a LOT of this as a teen and have seen worse situations that just took a bit of thinking before hand.
    edited 2013-08-13 17:33
    Danger lurks everywhere with tree removal. My neighbor Ed was trying to remove a sizable tree stump from his front yard. He dug around it a fair amount, then wrapped a chain around it, and wrapped the other end of the chain around his old pickup truck's bumper. Over the course of a day, he tried gently pulling, spinning his tires, then backing up and taking some running starts to jerk the tree out. A neighborhood spectacle, people were coming from blocks around, even bringing lawn chairs to watch and make suggestions. After a while, he mangled his bumper up pretty bad and the stump hadn't budged. But Ed owned a trucking company. Next day he brought a BIG stakebed truck home to resume his quest. Again, lots of spectators watching. He pulled gently. He jerked. The stump barely budged. Embarrassed by his failure, he kept at it, getting a bigger & bigger runup and jerk on the chain. On his final attempt, the chain broke near the stump, and the tensioned chain shot elastically forward at his truck, smashing through his rear window, narrowly missing his head, and cracking his windshield.
    The next day, he hired someone with picaxes and chain saws to get rid of the stump.
    Long story short, be careful. It may be worth calling someone to do it instead or risking life and...
    ... limb. Sorry, I couldn't resist that one.
    edited 2013-08-13 18:01
    NWCCTV wrote: »
    ..Gravity will prevail once you cut the right branches from the tree....
    If he's got the main trunk of the fallen tree lodged in the branches of the tree still standing, then are you suggesting he cut limbs out of the tree still standing so the main trunk can fall through?
    If you're suggesting he cut the main trunk of the fallen tree from a cherry picker, then could he end up in a situation where the section still lodged could rotate toward where he's positioned?
    473 x 315 - 60K
    edited 2013-08-13 18:10
    ...the chain broke near the stump, and the tensioned chain shot elastically forward at his truck, smashing through his rear window, narrowly missing his head, and cracking his windshield.....
    That reminds me - if you use a rope as I mentioned above, do NOT use metal hooks or anything at the ends of the rope. Only have rope involved. By using hooks or chains at the ends of the rope, you're just adding mass to the thing, so if it snaps, it has a lot more killing power. Rope can fail but it usually fails before machinery will, and it's not nearly as deadly as chains or metal cables when it lets go.
    edited 2013-08-13 18:13
    One of my faves:
    edited 2013-08-13 18:20
    rjo__ hasn't posted anything today. I hope he didn't hurt himself!
    edited 2013-08-13 19:01
    This wouldn't be him, would it?
    edited 2013-08-13 19:10
    I have been so busy chasing a two year old and changing diapers, when he will consent to wear a diaper, I haven't had time to consider that tree stuck up in the trees:)
    I've been looking at it... and it is irritating me... so, it is only a matter of time:)
    edited 2013-08-13 19:52
    I merely suggested a Cherry picker for safety reasons. This could actually be done fairly safely without one. From the pics it does not seem to be an overly large tree. A climber could have that out in no time. In suggesting a Cherry picker I would start from the bottom limbs and work torwards the top portion of the tree that is stuck. A couple of 3/4 inch manilla ropes tethered in the center and about two thirds of the way up to the base of one of the other trees so when it is cut it is forced downward. You are inevitbly going to damage some of the other tree but doing it this way minimizes that damage. But, as others have suggested, if you are unsure of yourself call in the experts.
  • xanaduxanadu Posts: 3,347
    edited 2013-08-13 19:58
    put a treadmill under it, should take off
    edited 2013-08-13 20:22
    rjo__ wrote: »
    I have been so busy chasing a two year old and changing diapers...I haven't had time to consider that tree...
    I feel your pain. In that case, it's time to call in the woodchucks.
    They don't need no stinking ropes.
    edited 2013-08-14 11:07
    How much wood can a wood chuck chuck if the wood chuck (is packing serious heat)???
    edited 2013-08-14 11:14
    Maybe an Elev-8 with a wood cutting prop?
    -or-
    If you go the woodchuck route, I suggest this one...
    C.W.
    261 x 350 - 22K
    edited 2013-08-14 13:50
    I wonder if a quadrover would have the pull?
    ROFL... thank you veryyyyyy much.
    Today, I had to decide how long I should let the two year old tease the dogs with treats... how much food he should be allowed to throw at me, and how much snot I should let accumulate before I stepped in over his vigorous objections:)
    The good news is that I have decided to make my escape via the UPNE http://www.propellerpowered.com/expo/ this weekend. I originally thought that I should stay
    home and help grandma with the kiddy, but then she announced that she was going to a meeting in Chi-town and that cinched the deal.
    Whooooo ha!
    Rich
