C2H5OH Gas Sensor Module
Tymkrs
Hi folks!
I'm working on a different project and hope to include this sensor - only issue is I'm having difficulty finding the code in the OBEX. I've also been looking through the documentation to see how I'd make my own board, but from the datasheet it looks like all you need is one potentiometer? So I'm wondering if anyone knows what the other chips/parts are on the Parallax C2H5OH sensor board?
Thanks for any additional information! I'll continue looking around to see what I can find.
Addie
Addie
Download the manufacturer's data sheet, MQ-3 from the Parallax product page. Figure 2 shows the application circuit, 5V for the heater and a 200kΩ potentiometer for RL.
The breakout board from Parallax has the potentiometer. In additon it has an op-amp that buffers the Vout to a test point, and a comparator that provides the alarm trip point.
Yeah, it looks like there are a few schematics out there that I can check. But I still haven't been able to find the Spin code provided (back in the day) by Parallax?
Tracy, you're right that there wasn't a specific program for the Propeller, but there are PWM objects, which is why we didn't make one. On the new website we'll link to an object eventually that can be used for such a purpose.
I'd like to pick up the analog output with the breakout board #27983 and CO Sensor, is this possible on a Propeller Activity Board through the A/C pins? If not, how about with the Professional Board?
As a newbie I'd be thankful for some help, especially with the schematic and a starting point with Spin or C.
BTW Can I connect the board to my Activity Board to 5V without any additional resistor, or should I connect it to 3.3V with a 3.9 kΩ10 kΩ resistor as the manual recommends?
You can pick the buffered analog voltage from TP1. It won't be very high, though I don't remember the range at the moment. And yes, you should still use a series resistor on the ALM output. It has a 1K protection resistor, but that's not intended for the Propeller so much as it is protection against an connected I/O pin being set wrong. However, since there is 1K in series you can use a 3.3K-4.7K in series. You will use 5V power from the Activity Board for power and the analog output from TP1 can go directly into the A/D channel on the board. As for code, there is a driver for the ADC on the OBEX that was written by Jon McPhalen in SPIN. You would have to use a known gas level to calibrate your readings from the sensor though.
I tried the sensor on a BS2 Boe-Bot so now I understand a bit more how it works.
The sensors do need 10-15 minutes of 'heating' before they stabilize as also the data sheet is informing.
Thx for the help!
Thanks for the update. Yes, it is reasonable to expect that the voltage ranges from each type of sensor will be different. There will no doubt be some minor differences between sensors of the same type. Each would require calibration. Glad to hear that you got things working though.
