LED Cardiac Simulator
Hi everyone! After nearly 1.5-2 years of learning how to program, using the Propeller, learning how to design/create boards, and getting a little push from the Micromedic competition - I present, Tymkrs HeartMe, the LED Cardiac Simulator!
[video=youtube_share;VLxsLt2oI4A]
If interested in more details about the project: http://www.tymkrs.com/kits/led-heart-simulator/
And if interested in getting one (we're only waiting on boards now): https://www.tindie.com/products/tymkrs/tymkrs-heart-me-v2/
This is also my micromedic video entry
I will show this to my daughter in law, she is a cardiovascular nurse too. I know she will be interested.
Thanks for sharing. and good luck with the Micromedic contest.
-Tommy
I have been following in the back row for a while, but I am proud of you being able to put the concept together, the programming, and the actual PC board in record time, for a NooB.
Great entry for the contest!
Jim
Great project !!! I wonder what it would have to say about my heart rhythm after biking 26 miles which is what I've been averaging a day .... half of it in the morning and then the other half in the evening. I'm sure a lot better off now then I was two months ago. Areas of the trail I had trouble with, I just breeze through now. :-)
PS. I meant to get you that circuit that will let you read your heart beat via an IR sensor passing through your finger tip. I think I might have a better biasing circuit for the IR that makes that even easier.
Here's a link btw showing the leds a bit brighter:
Thought you would be interested in this.... :-) Sorry it took so long. I wasn't happy with the original front end detector circuit that I was using. This one is much better. My resting heartbeat clocks in at about 55 to 58 beats per minute! Yay!!
http://forums.parallax.com/showthread.php/149216-DEMO-IR-Heartbeat-detector
B.Z. on a really great project
Frank
Thanks Frank! Um, so the heart portion is available: https://www.tindie.com/products/tymkrs/tymkrs-heart-me-v2/
In terms of the rest of it, I'd love to make it a kit, but I haven't be able to find a good source of solenoid + valve plate combination that's easily/cheaply acquired. And I'd also love to try doing some form of ecg from this- I am sure the Propeller could handle it. I just don't know how to start doing it haha. I've been meaning to look at previously done ecg projects by folks here, but it may have to wait until after the Micromedic contest ends
Addie
It was a submission to the National microMedic Contest:
http://learn.parallax.com/contest/micromedic
So besides it being a project for Micromedic as Publison has said - it was a project that allowed me to combine my cardiovascular surgery career with my electronics hobby. It's an led heart simulator, and has already been used to help student nurses learn about rhythms and patient assessment!
I just used PlayWAV.obj from the OBEX, made a little wav file with Audacity to sound like what I wanted it to sound like, and then referenced this forum topic: http://forums.parallax.com/showthread.php/148063-MISSING-documented-circuit-setup-for-propeller-audio-output for the circuit. Hope this helps!
Here it comes the problem: I have not problem with audio circuits nor with WAV player Spin, feel very at easy with them, but have not a clue how to make the files with the cardiac sounds... .... Can you sell, donate or whatever your wav files?? sorry but it is my only resource down here in Peru!!
http://download.cnet.com/Audacity/3000-2170_4-10058117.html
On the top, click generate, and I think I chose Risset Drum. Didn't change any of the settings, just clicked on it. You get this wave file. But it's clearly too big and not saved in the format that the PlayWAV obj wants. So I took the majority of the end of the tail and after selecting it, I cut it:
And then I zoomed in and kept cutting until I got the first maybe....0.01s worth of sound? And you can cut whereever you'd like for the sound you want. Then I just looked at the format that the code wanted me to save it in.
For the circuit, I would recommend a stereo circuit. The ones I've linked are mono and didn't sound as good as the one that's used on the PropBOE, and that's in their schematic files here on the website. Hope this helps!
