Wiznet POE Question
NWCCTV
I see Parallax is now carrying the Silvertel POE Module. This is a step in the right direction for a project I have had on my mind for several years now. However, I need 12V. The Wiznet Ethernet board says it is compatible with the AG-9050 but no mention of the AG-9120 which is in the same line but is 12V. Does anyone know of a way I could make the Wiznet Module work with the AG-9120 without compromising anything?
injects any arbitrary DC voltage into the Rx/Tx pairs. I was fooled by products that supported 'PoE' but fortunately didn't fry anything with real PoE. Be careful!
802.3af runs an isolated -48VDC or -54VDC up to 15.4W. For this, you'll need a corresponding PSE supply on the other end.
Unfortunately, this card appears to outputs only 5V. To get 12V, you'll need an external converter to step it back up.
