printing midi data to serial terminal - troubleshooting
Hi all,
I am trying to print midi data on pin 0 to my serial terminal. I think I may have the wrong type of optocoupler in my circuit, but I thought I would run my code by you all before I buy new ones. Because I'm reading and writing serial data from two different sources I thought maybe there could be an issues with different baud speeds in my code. Here is what I have:
Let me know if this looks fine to you all for my purposes. If so, than I know it's my midi schematic. I should mention that my serical code is reading all -1 unless I put the if block.
Thanks!
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ pst : "Parallax Serial Terminal" midi : "FullDuplexSerial" PUB main pst.Start(115200) midi.start( 0, 1, 00, 31250 ) repeat if midi.rxcheck <> -1 pst.dec(midi.rxcheck) pst.str(string(" "))
Thanks!
I'll try this out when I get home.
Andy
Thanks for the tips!
