Propeller I2C Interface Questions (3.3V or 5V) - Page 2 — Parallax Forums
2»
  • BuildAMachineBuildAMachine Posts: 7
    edited 2013-08-06 21:19
    The TXS0102 does seem like a promising chip (I just noticed that the voltage levels on either side of the shifter/buffer can be equal)\
    I was just wondering the tolerance of the chip to voltage "imperfections"-
    e.g. If the chip could still handle the VCCb ("lower side") input could be slightly lower (3.25V) than the VCCa ("higher side") input (3.35v), in worst case scenario, if some of the regulators are running a bit low/high respectively...
    That may be the area in which the PCA9512 would be slightly (but not much) better- it can interface different voltages, and the "high side" and "low side" don't matter
    Sorry for my lack of eloquence in explaining
    BuildAMachine
    edited 2013-08-06 21:33
    Dr_Acula wrote: »
    You are right, yikes!
    How could one fix this? 10k pullups to 5V and assume the leakage current is low enough to be ok?
    As Phil pointed out in post #14, the Prop's diodes will pull the line back down to 3.3V.
    Prior to Phil pointing this out, I also would have thought pullups to 5V would have worked.
  • AribaAriba Posts: 2,694
    edited 2013-08-06 22:49
    Duane Degn wrote: »
    Actually to 3.3V + Diode forward voltage ~ 3.3+0.6 = 3.9V. Still a bit low for a 4V high level.
    Andy
    edited 2013-08-07 08:37
    BuildAMachine,
    That's a good question about going between two 3.3V circuits, using the TXS chip, when the B side may end up slightly lower at 3.3V nominal than the A side due to regulator tolerances. I don't see leeway in the data sheet. I'd expect there would be some on the order of 0.1V, but I'd like to know for sure before counting on it. That is not an issue with the NXP chip, because it does not care which side is lower or higher.
