Bug in Dns.spin W5100 / W5200 driver/demo
Some misshaped code does not what it is supposed to do in Dns.spin.
should be
or should it be
Enjoy!
PUB ResolveDomain(url) | ptr, dnsPtr bytefill(@ip1, 0, @dnsIps-@ip1) bytemove(@urlBuff, url, strsize(url)) byte[strsize(url)] := 0 ' <--- wrong ...
should be
PUB ResolveDomain(url) | ptr, dnsPtr bytefill(@ip1, 0, @dnsIps-@ip1) bytemove(@urlBuff, url, strsize(url)) byte[@urlBuff][strsize(url)] := 0 ' <--- better ...
or should it be
PUB ResolveDomain(url) | ptr, dnsPtr bytefill(@ip1, 0, @dnsIps-@ip1) bytemove(@urlBuff, url, strsize(url)+1) ' <-- same result one line less ...
Enjoy!
Edit: Repo updated.
found the change in the repo before looking at the forum...
You did a lot of work there and well written code. Nice to read and extend.
I am using the spinnerette, so sockets are a very expensive resource.
I like the DHCP object, it needs one socket as far as I followed. But just once in a while. This can be shared with NetBIOS.
But the bummer is your NetBiosUnitTest. I bow deep. I was just reading some wonderful book (http://book.huihoo.com/implementing-cifs/NetBIOS.html) over implementing CIFS. And stumbled over it in the w5200 driver section of the code.
You are almost there! Wow. NetBIOS over TCP/IP on the prop...
If my time allows me to do I will dig deeper into this.
NetBIOS name registration/resolution is nice on the spinnerette. it will make life way more easier.
changed the prefix to SOLVED...
Enjoy!
